Author Topic: Kufatec Wiring Adapter  (Read 4208 times)
Offline Jono76
« on: February 28, 2010, 04:48:02 pm »
I received my Halogen to Xenon wiring adapters in the post this week but I have a small query - what is the bare exposed wire for halfway through the loom  :ashamed: :ashamed:
Many thanks in advance for the help and apologies for the blurred pic  :happy2:
Offline ollie288
Re: Kufatec Wiring Adapter
« Reply #1 on: February 28, 2010, 04:49:26 pm »
To wire up the high beam xenons to the electric module under the steering wheel I believe.  :happy2:
Offline QD MBE
  • -Receive: 102
« Reply #2 on: February 28, 2010, 04:50:52 pm »
That is the feed for the Xenon shutters.  If you want xenon main beams, you will need to run a wire to the Cent Conv Module , and join it to these on each light.
Offline QD MBE
  • -Receive: 102
« Reply #3 on: February 28, 2010, 04:52:27 pm »
The wire is pin 11 in the pic below.
Whole thread - http://forums.motivemag.com/zerothread?cmd=print&id=3597373
Offline Jono76
« Reply #4 on: February 28, 2010, 05:27:41 pm »
Cheers Stokeballoon  :happy2: :happy2:
Now it all makes sense, when you replied to my question the other day I thought I would have to re-wire the adaptor  :ashamed: :ashamed: :ashamed: :ashamed: :ashamed:
Offline mortygttdi
  • -Receive: 146
« Reply #5 on: February 28, 2010, 06:15:22 pm »
The correct term is to make the xenons, bi-xenon,  put a couple of repair wires on the end and one goes to A5 and the other to D6.
I think i must have done this a few times now.
Darren
Offline Jono76
« Reply #6 on: February 28, 2010, 06:18:25 pm »
Anyone know where the Central Electronics Control Module is located???
Offline mortygttdi
  • -Receive: 146
« Reply #7 on: February 28, 2010, 06:22:12 pm »
If you sit in the car and take the small cubby out the one to your right knee...its there just to the side of the fuse box.
Darren
Offline Jono76
« Reply #8 on: February 28, 2010, 06:23:37 pm »
Cheers Darren  :happy2: :happy2:
Offline QD MBE
  • -Receive: 102
« Reply #9 on: February 28, 2010, 06:36:43 pm »
Darren
Darren, Have you ever measured the Voltage at D6/A5 with mainbeam selected?
I did, and got about 0.6V, the shutters work fine though with the engine running, with the ignition on and engine not running, they work ok, if a little slow to react.
Just interested to hear if you had ever seen this.
D
Offline Jono76
« Reply #10 on: February 28, 2010, 07:14:38 pm »
How easy is it to run a repair wire from the loom to the control unit?!?!?
Also, is it advisable to get the repair wire from VW (if so what part no.) and if not what sort of wire is best??
« Last Edit: February 28, 2010, 07:16:59 pm by Jono76 »
Offline QD MBE
  • -Receive: 102
« Reply #11 on: February 28, 2010, 07:40:09 pm »
The repair wire is listed above in the diagram - 000 979 025.  It is a small (12") long wire with the correct terminal that is required at the Cent Con Module on each end.
You will have to run a wire from behind each headlight (spliced to the extra wire at the adaptor), through the bulkhead behind the battery, and behind the dash to the CCM, then splice the wires to the repair wire cut in two.
I removed the plugs from the CCM and this will allow you to push the new terminals into the correct hole in the plug, refit the plugs and all is good.
Some coding to tell the car it now has Bi-Xenons fitted, and ll should be good.
Offline QD MBE
  • -Receive: 102
« Reply #12 on: February 28, 2010, 07:40:54 pm »
Where are you based?
Offline Jono76
« Reply #13 on: February 28, 2010, 07:44:04 pm »
Northwich, Cheshire!!
Offline QD MBE
  • -Receive: 102
« Reply #14 on: February 28, 2010, 07:49:06 pm »
you going to Ultimate Dubs?  Happy to show you whats what then.
