Author Topic: Wheel offset  (Read 5691 times)
Offline kris
Wheel offset
« on: January 03, 2009, 12:27:13 pm »
I'm looking to get some BBS CH 18x8.5. The ones I've got my eyes on are ET35 and running 235/40/18 tyres. Would there be any fitment issues onto a mk5 GTI with standard suspension? Offsets always confuse me, so any help is greatfully received! Thanks.  :happy2:
Offline gazbutS3
Re: Wheel offset
« Reply #1 on: January 03, 2009, 12:59:38 pm »
They won't fit I don't think, they are an inch wider than std so would stick out 12.5mm approx, then with the lower offset that would be a further 15/16mm so total 28.5mm more sticky out, to much me thinks :smiley:
Offline cmdrfire
    • Commander Fire - my blog
Re: Wheel offset
« Reply #2 on: January 05, 2009, 11:39:10 am »
I'm running 235/35/19 with an ET45 offset IIRC with no issues.
Offline gazbutS3
Re: Wheel offset
« Reply #3 on: January 05, 2009, 07:41:21 pm »
KRIS was asking about a ET35 which I think will be to low with an 8.5inch rim :smiley:
Offline kris
Re: Wheel offset
« Reply #4 on: January 06, 2009, 09:15:31 am »
Thanks for your help guys. I've bought ET50 rims now which I know will fit OK because they came off a mk5!  :happy2:
matt a
Re: Wheel offset
« Reply #5 on: January 06, 2009, 10:42:35 am »
They fit perfectly mate! ;)
Hope you enjoy them.
Offline Mark M
  • Loves to detail :)
Re: Wheel offset
« Reply #6 on: January 15, 2009, 08:17:23 am »
The best fit is a 44/45 offset on an 8.5" width.
If you have 18's, you should be fine on a 225/40 tyre on a 8/8.5.
If slammed on 19's, a 215/35 tyre on an 8.5" gives the required stretch :)
Offline RunRabbit
Re: Wheel offset
« Reply #7 on: April 02, 2009, 05:56:37 pm »
Will 9" 19's fit on the Mk5?
They're ET41, whats the std offset?
Re: Wheel offset
« Reply #8 on: April 02, 2009, 08:58:41 pm »
No they would be a problem Wabbit, that again is about 28 mil further poke than a standard monza + i dont know whether you would get rubbage on the inside with that width of wheel.  :smiley:
Offline RunRabbit
Re: Wheel offset
« Reply #9 on: April 02, 2009, 09:01:55 pm »
 :sad:
Thanks for the info, no audi split rims for me then  :sad:
Offline TurboTrev
Re: Wheel offset
« Reply #10 on: April 03, 2009, 06:27:05 pm »
:sad:
Some 19" Audi splits are ET48, which would be fine. :happy2:
Re: Wheel offset
« Reply #11 on: April 03, 2009, 10:29:12 pm »
:sad:
You'd probably still struggle if they were 9" width though, especially at the front!
Offline TurboTrev
Re: Wheel offset
« Reply #12 on: April 07, 2009, 05:49:20 pm »
:sad:
True I think the 9" are ET42 which is no good, but the 8.5x19 versions are ET48 which is fine> :happy2:
