Author Topic: Fitting r32 Brake MC  (Read 2003 times)
Offline bazmk5
« on: December 07, 2019, 11:52:05 pm »
Has anyone upgraded to the 23.81mm brake MC?
I recently fitted R32 front and rear brakes and im having more travel in the brake pedal. I suspect its the smaller 22mm MC to blame for this and Im considering upgrading to the 23.81mm.
Has anyone done this? is there much involved?
Offline colesey
  • -Receive: 89
Re: Fitting r32 Brake MC
« Reply #1 on: December 08, 2019, 06:35:58 am »
Not sure what year your car is however mine (07 chassis registered in Aug 06) already has the larger MC fitted. Have a look to see if it has 23 stamped on it.  Is however inevitable that you will get more pedal travel having fitted calipers with larger pistons all round.
« Last Edit: December 08, 2019, 07:40:36 am by colesey »
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ctoqiqvo3bllf6u0rl7v21psvh&/topic,19740.0.html
« Reply #2 on: December 09, 2019, 01:24:46 pm »
I would suggest re-bleeding the brakes first. When I upgraded to r32 fronts I didnt notice any difference apart from much better braking
« Reply #3 on: December 13, 2019, 06:22:02 pm »
As above, probably a bit of air on the system.   When properly bled, the first cm of pedal travel is a touch softer than the standard brakes but otherwise should feel a lot stronger.
Offline Stupots
  • -Given: 18
« Reply #4 on: January 10, 2020, 08:55:08 am »
Did you get this sorted @bazmk5 ?
I replaced mine with R32 rears and Mk7 Golf R fronts on a 22mm MC (I'm a TDI) and after a few bleeds the brake feel was OEM but with extra Gs :)
So as @Pudding said, it's unlikely the MC is to blame.
« Last Edit: January 11, 2020, 09:32:25 am by Stupots »
« Reply #5 on: January 10, 2020, 05:06:21 pm »
I think only the TTRS/RS3 got a substantially bigger MC (much bigger calipers) at 25.something mm.  Even MK7s still use the same 23mm size as found in the ED30/late GTI, so regular S3/7R/R32 sized brakes shouldn't have a squidgy pedal.
