Author Topic: Help!!! Abs long conding  (Read 1375 times)
Offline arsammehmood
  • Newbie
« on: December 12, 2019, 01:44:54 pm »
Hi All,
I currently own a Golf Gt sport 140 and following an unsuccessful cluster swap to highline I have now lost the Abs/Esp long coding. Can someone please help me with the long code?
VIN: WVWZZZ1KZ9W033645
Model: Gt Sport TDi (2008 plate)
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 01316 785 00200
   VCID: 74E7BAF5D76ABCE1DB-8020
3 Faults Found:
03306 - Coding Not Valid
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 94
                    Mileage: 148282 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 4161
                    Count: 43776
                    Count: 65280
                    Count: 0
                    Count: 0
00003 - Control Module
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Status: 01100101
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 94
                    Mileage: 148282 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 143
                    Count: 45056
                    Count: 65280
                    Count: 0
                    Count: 0
01042 - Control Module; Not Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 94
                    Mileage: 148282 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 7
                    Count: 2
                    Count: 12288
                    Count: 195
                    Count: 44032
                    Count: 65280
                    Count: 0
                    Count: 0
« Last Edit: December 12, 2019, 11:37:44 pm by arsammehmood »
Offline ady-uk
  • -Given: 19
  • -Receive: 24
Re: Help!!! Abs long conding
« Reply #1 on: December 13, 2019, 01:09:25 pm »
If you have a genuine VCDS and registered, you can ask Rosstech for coding  :pomppomp:
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
  • Newbie
« Reply #2 on: December 13, 2019, 04:27:04 pm »
Hi Ady,
Unfortunately, I don’t have the genuine VCDS so unable to ask Rosstech. Is there no other way ?
Offline Usual Suspect
« Reply #3 on: December 14, 2019, 08:42:39 pm »
Hi
I can get this for you
Drop me a PM
Many thanks
