Author Topic: HPFP WIRING DIAGRAM???  (Read 2050 times)
Offline TechyTom
  • Newbie
  • Techy by trade
« on: December 14, 2019, 09:34:54 am »
Hi all,
I bought a 2005 mk5 gti AXX about a month ago, bought it from a chap who said the cam chain, cambelt, waterpump ect was changed recently. However after 20 days of owning the car the chain snapped and caused a lot of damage. anyway I replaced all the parts and the engines running as smooth as a whistle apart from the fact the EML and EPC light are on relating to - P2294 - High pressure fuel pump regulator valve open circuit and then the same again but with P2294P? As is relating to Open circuit ive checked the fuses, relays ect and theyre okay. Theres no power getting to the Thrust sensor, N297 sensor and the exhaust cam position sensor which all run off the same loom. Ive replaced the cam follower and that's all okay, the car is stuck in limp mode.
Has anyone got wiring diagrams for the HPFP/Electrical system that provides it?
Many thanks,
Tom.  :thinking:
- TechyTom
