Author Topic: Cam follower  (Read 4022 times)
Offline St282
Cam follower
« on: December 17, 2019, 01:41:00 am »
Hey guys,
What do you guys think, if this cam is still usable? Or time to change?
Offline neilw
Re: Cam follower
« Reply #1 on: December 19, 2019, 12:57:25 pm »
Change it. If you put it back in you'll be constantly worrying if you've done the right thing.
Edition30 #0002 R-Tech Stage2
Offline St282
Re: Cam follower
« Reply #2 on: December 19, 2019, 01:13:33 pm »
I changed it with the same thought in mind.
Thanks man
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Re: Cam follower
« Reply #3 on: December 19, 2019, 01:35:30 pm »
Yep, stick a new one in, not expensive.
Offline GPem3:16
Re: Cam follower
« Reply #4 on: July 02, 2020, 04:05:47 pm »
How easy a job is this?
Or is best to leave for seevice time?
Offline St282
Re: Cam follower
« Reply #5 on: July 02, 2020, 04:27:55 pm »
It’s fairly straightforward, just pop out the hpfp and replace it. Getting the hpfp off the the only “hard” bit.
When did you last replaced it? That depends whether to change it now or later.
Offline GPem3:16
Re: Cam follower
« Reply #6 on: July 02, 2020, 04:29:54 pm »
To my knowledge never
Crrently on 118k so I know it needs doing. Just don't have the balls to do it myself!
Will the hpfp need priming after removal??
Sent from my SM-G955F using Tapatalk
Offline St282
Re: Cam follower
« Reply #7 on: July 02, 2020, 04:36:35 pm »
Oh my... im surprised your engine is still running mate. Im 100% sure your follower has a hole in the middle at this point.
How long til service? Id send it right away to change it then service at same time.
Or, change it yourself (youtube tutorials are good) then service when its ready.
Either way, change it asap ur engine is at high risk of seizure.
Offline St282
Re: Cam follower
« Reply #8 on: July 02, 2020, 04:38:25 pm »
Don’t do anything to the hpfp just remove it. What engine do you have?
Offline GPem3:16
Re: Cam follower
« Reply #9 on: July 02, 2020, 04:47:43 pm »
 BYD.
I will look at getting this done asap then.
Cam follower kits on ebay any good??
Or dealership??
Offline St282
Re: Cam follower
« Reply #10 on: July 02, 2020, 04:50:33 pm »
BYD.
Or dealership??
Ebays are ok depends who you getting it from. I got mine from ecstuning.com
Dealership are too damn expensive. You can get like 4 for the price of 1.
You eending it to change at dealership? You could save alot if you do it yourself mate
Offline GPem3:16
Re: Cam follower
« Reply #11 on: July 02, 2020, 04:52:09 pm »
Ill have a look at doing it myself.
Thanks for the heads up. Ill keep you updated
Offline GPem3:16
Re: Cam follower
« Reply #12 on: July 02, 2020, 04:54:54 pm »
I dont suppose you have a photo of what yours looked like and what mileage it had done
Offline St282
Re: Cam follower
« Reply #13 on: July 02, 2020, 04:57:47 pm »
I don’t remember the mileage but the picture above in this thread was the one replaced. Ive replaced it several times now.
Its a common practice to replace it every 20,000-30,000km
Offline St282
Re: Cam follower
« Reply #14 on: July 02, 2020, 05:07:52 pm »
I was only doing a routine checkup on my engine and checked the follower at 20,000km and decided to change it when i saw it. Could have gone another 10,000km but since i took it out and had spares on me might as well.
