Author Topic: Intake valves  (Read 2586 times)
Offline St282
Intake valves
« on: December 22, 2019, 05:50:27 pm »
I did a boroscope in my intake valves today and these are the pics. What do you guys think of it’s gunk condition? Bare in mind its a 06 GTI FSI.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Intake valves
« Reply #1 on: January 03, 2020, 11:05:44 am »
They look well covered in soot, walnut blasting would sort that, then maybe a catch can to help prevent, it won't stop it getting covered in soot again but will help slightly...
If you go to the likes of R-tech, they could test your injectors when or if you get the walnut blasting done... 2 birds 1 stone... :driver:
Silver is the way !
Offline St282
Re: Intake valves
« Reply #2 on: January 03, 2020, 11:07:41 am »
To me the soot is sitting on top of the valve ring. Apart from that the stems and surroundings looks ok to me. You think so?
Btw this is a 15 year old mk5 GTI
  • -Receive: 689
Re: Intake valves
« Reply #3 on: March 06, 2020, 03:48:13 pm »
That is barely any build up at all compared to some.  I certainly wouldn't bother stripping it down for a clean up at that level of build up.
It's mostly the short journey cars, or worn out engines, that suffer the worst build up.  Keep the revs and engine heat up and the carbon won't stick so much.
Offline GPem3:16
Re: Intake valves
« Reply #4 on: July 21, 2020, 07:28:01 pm »
These were mine after 118k
Before and after Walnut blasting.
Had a misfire due to build up and the difference afterwards was night and day.
Sent from my SM-G955F using Tapatalk
Offline St282
Re: Intake valves
« Reply #5 on: July 24, 2020, 04:11:45 pm »
Nice and clean now huh. I bet drives alot better.
Somehow mine was never that thick with gunk thankfully..
Offline GPem3:16
Re: Intake valves
« Reply #6 on: July 24, 2020, 04:30:15 pm »
Probably depends on city driving vs motorway driving im guessing.
But was sooooooo much nicer to drive now.
Offline colesey
  • -Receive: 89
Re: Intake valves
« Reply #7 on: July 24, 2020, 06:48:02 pm »
Did you have the injectors cleaned at the same time?
Offline GPem3:16
Re: Intake valves
« Reply #8 on: July 24, 2020, 07:17:48 pm »
Yeah
