Author Topic: Engine lights on here's my VCDS print, could you please help?  (Read 2160 times)
Offline shandyandy77
« on: January 09, 2020, 10:01:02 pm »
Hi all
Mk5 GTI 2006. All my engine lights are on after a battery change - EPC, ABS, Power Steering. Car starts fine and idles fine. Won't rev over about 3500 and stutters. Immediately before the battery change it drove fine to full boost.
ABS and traction control is the rear ABS sensor which I am changing and actually these lights were already on I just ignored them for a while (although it snapped off this evening getting it out!!!!).
So I think it's mainly the engine module codes I need some help with please to know what to look for.
Here is my VCDS report.
Thanks in advance everyone!
Wednesday,08,January,2020,14:50:58:49243
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WVWZZZ1KZ6W112984   License Plate:
Readiness Status: 0110 0101
Exhaust Gas Recirculation: Passed
Oxygen Sensor Heating: Failed or Incomplete
Oxygen Sensor(s): Failed or Incomplete
Air Conditioning: Passed
Secondary Air Injection: Passed
Evaporative Emissions: Failed or Incomplete
Catalyst Heating: Passed
Catalytic Converter(s): Failed or Incomplete
Thursday,09,January,2020,14:18:31:49243
www.Ross-Tech.com
Mileage: 158530km-98505mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 76
VIN: WVWZZZ1KZ6W112984   Mileage: 158530km-98505miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine        Labels:. 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 J    HW: 1K0 907 115 F
   Component: 2.0l R4/4V TFSI     0030
   Revision: --H14---    Serial number: VWZ7Z0E2901999
   Coding: 0403000318070060
   Shop #: WSC 00638 210 89272
   VCID: 2D06F25F411D3BDF521-8078
5 Faults Found:
012423 - Voltage Supply Relay for Engine Components
               P3087 - 004 - Electrical Malfunction
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 158535 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:18:29
             Freeze Frame:
                    RPM: 292 /min
                    Load: 53.3 %
                    Speed: 0.0 km/h
                    Temperature: 78.0°C
                    Temperature: 22.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 11.049 V
001112 - Evap System Purge Control Valve (N80)
               P0458 - 002 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 158535 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:18:30
             Freeze Frame:
                    RPM: 839 /min
                    Load: 29.4 %
                    Speed: 0.0 km/h
                    Temperature: 78.0°C
                    Temperature: 21.0°C
                    Voltage: 11.938 V
000052 - Turbocharger Bypass Valve Control Circuit
               P0034 - 002 - Low
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 158535 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:18:30
             Freeze Frame:
                    RPM: 839 /min
                    Load: 29.4 %
                    Speed: 0.0 km/h
                    Temperature: 78.0°C
                    Temperature: 21.0°C
                    Voltage: 11.938 V
000581 - Solenoid Valve  for Boost Pressure Control (N75)
               P0245 - 002 - Short to Ground
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 158535 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:18:30
             Freeze Frame:
                    RPM: 839 /min
                    Load: 29.4 %
                    Speed: 0.0 km/h
                    Temperature: 78.0°C
                    Temperature: 21.0°C
                    Voltage: 11.938 V
008852 - Fuel Pressure Regulator Valve (N276)
               P2294 - 004 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 158535 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:18:30
             Freeze Frame:
                    RPM: 1373 /min
                    Load: 12.9 %
                    Speed: 0.0 km/h
                    Temperature: 78.0°C
                    Temperature: 21.0°C
                    Voltage: 12.065 V
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Component: ESP FRONT MK60      0102
   Revision: 00H13001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 71BE2E2F9DA51F3F369-8024
3 Faults Found:
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
            008 - Implausible Signal - Intermittent
01435 - Brake Pressure Sensor 1 (G201)
            012 - Electrical Fault in Circuit
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 BE
   Component: ClimatronicPQ35 090 0808
   Shop #: WSC 00000 000 00000
   VCID: 6B823C47BF89F5EF0C5-803E
No fault code found.
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000002270188
   Coding: E58D8F2700041800001400001400000000087F075C
   Shop #: WSC 00000 785 00200
   VCID: 2B02FC477F0935EF4C5-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00065493
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00207646
   Shop #: WSC 00000
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: 38 AIRBAG VW8   018 2200
   Revision: 02018000    Serial number: 0038MD04Y9KR
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3B22CC078F69A56FDC5-806E
   Subsystem 1 - Serial number: 6332MSME0D584B00C
   Subsystem 2 - Serial number: 6342MSME0D366175D
   Subsystem 3 - Serial number: 6352QSME03343659A
   Subsystem 4 - Serial number: 6362QSME07535057A
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 634 0070
   Coding: 0000012
   VCID: 76B41D33F4CB3807E3B-8022
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 962 D
   Component: KOMBIINSTRUMENT VDD 4312
   Coding: 0003403
   Shop #: WSC 00638 210 104187
   VCID: 323CE123582364270F3-8066
Address 19: CAN Gateway        Labels:. 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105C130CC7
   Coding: 3D0F0740070001
   VCID: 2A0CF94370F32CE7B73-807E
2 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 28
                    Reset counter: 254
                    Mileage: 158533 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 04:06:02
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 28
                    Reset counter: 254
                    Mileage: 158533 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 04:06:06
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 4312
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2390
   Coding: 0000564
   VCID: 3634DD33B44B780723B-8062
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V2.clb
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 3430E73BA2376A171DF-8060
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            000 - -
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AJ
   Component:    KSG              0401
   Coding: 01C802087F2D8405485AC69010CC
   VCID: 78A8130BFEDF4E77F17-802C
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Coding: 0000564
   VCID: 372AD037B341810F38D-8062
Address 56: Radio
Cannot be reached
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
1 Fault Found:
00437 - Rear Right Inner Parking Aid Sensor (G335)
            006 - Short to Plus
End----------(Elapsed Time: 00:55, VBatt start/end: 12.2V/12.2V)-----------
'07 Edition 30 #1173 Stage 1 | '98 Mk3 16v | '89 Mk2 8v Big Bumper | '88 Mk2 8v Small Bumper | '91 Mk1 Cabriolet | '09 T5 Campervan
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Re: Engine lights on here's my VCDS print, could you please help?
« Reply #1 on: January 09, 2020, 10:14:02 pm »
Post this than on Ross tech, you usually get a decent response quickly.
Offline GVK
  • -Receive: 67
    • GVKmotorsport
« Reply #2 on: January 10, 2020, 01:29:39 am »
Thats a lot of info to trawl through  :thinking:
What I would do is check on the Ross-Tech wiki page on the known faults - tip: google the fault code and ross tech and it will be an early search result.
Did you delete all the codes and recheck what comes back as solid faults?
A lot of those codes would be caused by the flat battery.
example this is the first code - http://wiki.ross-tech.com/wiki/index.php/19543/P3087/012423
You know the ABS will be causing the Steering fault too as I mentioned the thread explaining why in your other thread.
Sadly the ABS code brake pressure sensor usually requires an ABS pump to fix.
Seems to be a lot of open circuit codes in engine? Checked fuses as a simple test?
My guess it will be something to do with the fuel pressure fault why it doesn't rev.
http://wiki.ross-tech.com/wiki/index.php/18726/P2294/008852  - check the high pressure fuel pump. Might be damaged on top of the sensor, you can't buy the sensor new it's a whole pump.
« Last Edit: January 10, 2020, 01:51:50 am by GVK »
« Reply #3 on: January 10, 2020, 10:14:03 am »
Hi there
Thank you for this and for the link on the other post, that was very helpful.
Yes I deleted all codes a few times and they all come back.
Yes I checked all the fuses. I also checked the 2 relays next to the battery and the 2 ECU relays under the dash.
HPFP looks fine, the top isn't cracked.
Offline maxamplitude10
  • '07' ED30 Manual 3Dr
« Reply #4 on: January 10, 2020, 12:23:49 pm »
Have you let the vehicle run for a while following battery change?
I had a similar issue and they cleared after a moderate drive
Max
« Reply #5 on: January 10, 2020, 05:35:54 pm »
Sounds like a job for an auto electrician to trace some wiring faults.  A bad ground or a chaffed wire can take down quite a few circuits.
