Author Topic: Window issues since battery disconnecting  (Read 1006 times)
Offline maxamplitude10
  • '07' ED30 Manual 3Dr
« on: January 12, 2020, 02:08:17 pm »
Guys changed cambelt etc on Friday and disconnected battery. Forgot to plug in temp switch so when we re connected fans were always on. Reconnected plug and cleared faults and fans all ok again.
Now my full closure from key for windows doesnt work and I'm sure it used to have one touch window up function on window switch which doesnt work either. Any ideas?
Re: Window issues since battery disconnecting
« Reply #1 on: January 12, 2020, 02:39:05 pm »
Update... Reset limits and now one touch working but still no window or close function via key?
Help
MAX
« Reply #2 on: January 12, 2020, 02:50:37 pm »
Also passage door hasnt been unlocking opening via key for a while and when we had the computer on it, had fault code for passanger door locking module? What is this?
How do I replace it?
To confirm the full closure still worked with the faulty door module prior to us resetting codes?
