Author Topic: Auto wipers query.  (Read 2243 times)
Offline JR.303
Auto wipers query.
« on: January 14, 2020, 07:12:00 pm »
I find the auto wipers a bit of a pain and wondered if just a normal intermittant wipe is possible.
The drivers side blade (new Bosch aero) scrapes if it is not peeing down.
If so how?
Offline coolhandluke
  • -Given: 28
Re: Auto wipers query.
« Reply #1 on: January 14, 2020, 08:36:16 pm »
2nd click up of the wiper stalk should give you intermittent wipe and it's adjustable to.
Offline RobC
  • -Receive: 20
« Reply #2 on: January 14, 2020, 09:29:21 pm »
You can switch the Auto wiper function off with VAG Com I believe. Alternatively unplug the sensor behind the rear view mirror. This should give you adjustable intermittent wipe with the first click.
I thought 2nd click just gave you the slowest of the intermittent wipes and wasnt adjustable?
Offline JR.303
« Reply #3 on: January 15, 2020, 07:16:32 am »
Thanks, but I just looked through some old posts on here and it's not possible.
Oh well, no car is perfect!
Offline Robsmib
« Reply #4 on: January 23, 2020, 04:07:01 pm »
IMO Bosch wipers are sh*te, valeo ones all the time for me
Sent from my F5321 using Tapatalk
Offline JR.303
« Reply #5 on: January 23, 2020, 05:10:40 pm »
Thanks , I'll try them.
Offline Rampage
« Reply #6 on: January 24, 2020, 08:35:37 am »
I move the toggle switch on top of the stalk a few clicks along if the auto is being a pain, and it seems to act more like a traditional intermittent wiper.
Also, spray the screen with Rain X or equivalent and importantly wipe the wiper blades with it also and the wipers silently glide across your screen rather satisfyingly beautifully  :happy2:
« Reply #7 on: January 24, 2020, 08:57:04 pm »
Yep, that is the only way to revert to traditional intermittent - unplug the rain sensor.
Just to confirm:
Stalk down = 1 wipe, or hold down for max speed.
Stalk up 1 notch = Auto
Stalk up 2 notches = fixed speed 1
Stalk up 3 notches = fixed speed 2
On the MK4 you could replace the auto relay with a normal one and get basic intermittent.  On the MK5 they did away with that and the wiper has a controller built into the motor housing, so no such relay exists sadly.
TBH, I find the auto wipers absolutely fine 95% of the time.  If there is any weird or erratic behaviour, has the car had a replacement screen?  Most screen fitters totally bork the gel pack.  If they refit it with loads of air bubbles, you're never going to get proper auto behaviour.  Insist on a replacement sensor/gel pad.  Most just peel the old one off and stick it back on.  As Arnie says, that is "WRONG".
Offline ljc19630
« Reply #8 on: January 25, 2020, 09:29:27 am »
Any good Si02 product will assist in dispelling the water quicker. I use a chemical guys ceramic hydrowax and it’s brilliant to the point I can drive without the wipers on when it’s raining hard as the water beads off sooooo quick
Offline JR.303
« Reply #9 on: January 25, 2020, 11:02:50 am »
Thanks all!
Offline titchy
« Reply #10 on: January 25, 2020, 12:17:37 pm »
I always clay bar w./screen when cleaning the car
Offline Ricky123
  • -Receive: 27
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98436.0.html
« Reply #11 on: January 25, 2020, 06:37:33 pm »
I feel your pain, the auto wipers seem to have a mind of there own in mine.. I got rid of the Bosch blades and fitted valeo ones and gave the windscreen a good deep clean then a coat of rain-ex.
I only have to tap the stalk down manually now and then in light rain now and just stick it on speed 1 if of the motorway or heavier rain
59 red mk6 GTi 5dr
57 mk5 1.9 TDi match
22 a3 s-line competition 45 tfsiE
09 Suzuki GSXR 1000 (road going track sl*g)
Offline LC5F
  • -Receive: 80
« Reply #12 on: January 25, 2020, 08:03:54 pm »
My auto wipers also seem to do their own thing, turning down the sensitivity helped, less false positives - but not wiping in drizzle. I still would rather be with it than without.
After market blades always seem very chunky - not seen any as slim as OEM - how are Valeo ones for heftiness?
Offline JR.303
« Reply #13 on: January 28, 2020, 04:37:35 pm »
I've got some rainx now and hopefully will apply tomorrow.
