Author Topic: Oil usage  (Read 4949 times)
Offline probedb
Re: Oil usage
« Reply #15 on: January 25, 2020, 11:44:39 pm »
Mine uses more than I'd expect, more than a rotary and that's saying something since that actually burns the stuff as part of the combustion cycle.
In at R-Tech on Weds so swapping to Millers 5w40 and hope that lowers the usage.
I've very paranoid since I had an engine fail as a result of oil pump failure. Hence the balance shaft delete going in on Weds as well :D
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Re: Oil usage
« Reply #16 on: January 26, 2020, 08:21:53 am »
Are you going to cut the balance shafts and remove them?
Offline GVK
  • -Receive: 68
    • GVKmotorsport
Re: Oil usage
« Reply #17 on: January 26, 2020, 09:50:35 am »
That's pretty good!
 Bloody mayo all over the oil cap and in the rocker cover.  Damn those short journeys over winter!
Mines the same with mayo in the winter, what pi55es me off are the guys like Calvins car diary on you tube that say that its deffo a head gasket failure with mayo on an oil cap.  :fighting2:
Offline probedb
Re: Oil usage
« Reply #18 on: January 26, 2020, 07:59:59 pm »
Whatever R Tech do as they're doing the work :)
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Re: Oil usage
« Reply #19 on: January 26, 2020, 08:40:14 pm »
Can you post about how they do the delete please?
Offline Ricky123
  • -Receive: 27
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98436.0.html
Re: Oil usage
« Reply #20 on: January 26, 2020, 09:21:14 pm »
That's pretty good!
Yer I no what you mean about these car youtubers... I’ve had people in the past come to look at cars I’ve been selling and quoted what a youtuber has said for something :signLOL:
Mayo on the cap can be an indication of head gasket failure but it would never put me off when viewing a car.. time of year, what journeys the car has been on recently, how long it’s been sat etc can all cause condensation build up which can then cause mayo.
How the car is running, what does the coolant and oil look like, what’s it like on cold start and what’s the temp gauge reading are the things they should be telling there viewers too look at.
59 red mk6 GTi 5dr
57 mk5 1.9 TDi match
22 a3 s-line competition 45 tfsiE
09 Suzuki GSXR 1000 (road going track sl*g)
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Oil usage
« Reply #21 on: January 27, 2020, 08:12:16 am »
R-Tech will leave the balance shafts in place. Lock the shafts, pulley done up properly, not just 'windy gun'd' on and they'll be fine
