Author Topic: Alloy S3 front hubs & scirroco rear hubs - bolt/nut part number?  (Read 1080 times)
Offline eb198
« on: February 04, 2020, 11:11:43 pm »
Good evening Gents,
I know its been asked before but does anyone have the part numbers for the front and rear carrier bolts needed when converting to alloy hubs and lower arms?
Also the part number for the collared nut for track rod end and balljoint to prevent the insert pulling through?
Also front wheel bearing size/part number when converting to S3 alloy hubs, will they still take standard gti wheel bearings?
Many thanks in advance!
Cheers,
ed
Offline colesey
  • -Receive: 89
Re: Alloy S3 front hubs & scirroco rear hubs - bolt/nut part number?
« Reply #1 on: February 05, 2020, 05:38:59 am »
Here you go for the front, I got mine from Gavin at vagbolts
4x M14x55mm caliper carrier bolts N91084901
same nuts on both balljoints and tie rod ends - part number WHT000785
You can reuse your existing bearings and Passat B6 hubs are exactly the same as S3 ones but more plentiful and cheaper.
