Author Topic: GTI Track Car - Now big turbo, sidewinder.  (Read 38125 times)
Offline Mekaniko
Very nice build with very good components.
I'm curious for the pedal feel with this calipers, will you keep the original master cilinder?
Offline shannon-ob
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=v3k071tt9aa850d8tgbmns4ioo&/topic,124095.0.html
Thank you mate.
Yes will keep same MC. Pedal feel was great with old brakes. Should be ok with these too.
MY 3 DOOR 370BHP MANUAL GTI TRACK BUILD - WAVETRACK DIFF, CAGED, POLYCARBS, KO4, DB9 BRAKES, METH, BARTEK, VIS, HELIX PADDLE CLUTCH/SMF, FLOCKED DASH, 18X9 PRO RACE
https://www.mk5golfgti.co.uk/forum/index.php/topic,124095.0.html
Instagrams;
@shannon_ob
@dinger_developments
Offline Hypertuned
I've been told the sweet spot is 4 pot calipers on the stock brake master cylinder. If you go beyond that the MC doesn't move enough fluid to move all the pistons, leading to a longer than normal brake pedal. It's at this point when many upgrade to the Audi TTRS MC.
https://www.akstuning.co.uk/shop/home/497-genunine-ttrs-master-cylinder-upgrade-for-ea113.html
Sent from my SM-N9750 using Tapatalk
Offline shannon-ob
Exactly that mate. Was trying to explain this to someone on Facebook yesterday. I gave up!
Instagrams;
@shannon_ob
Offline Hypertuned
Sometimes you just gotta learn from experience. I went 8 pot and the pedal fell almost 2 inches before the brakes made contact with the discs then almost sent me through the windscreen. Lol
Upgraded my MC and all is good!
Offline Bulldugg
Don’t know if you posted it, but where did you get the red harness bar for the seat belts.
Offline shannon-ob
Hi mate,
It was custom made.
Instagrams;
@shannon_ob
Offline Bulldugg
Looks like a nice solid mount. Like the saying goes, “ Built, not bought”.
Offline shannon-ob
Here’s some pictures as promised of the powder coating!
Bought fresh FAG bearings front and rear.
Gotta take the Garage Midnight studs out the old hubs to fit to the new ones.
Most of the front parts.
All the powerflex bushes cleaned and re-greased.
All built up I do need to get the BC coilovers cleaned up next.
Some pictures of the rear set up:
Next the engine is getting dropped off to badger 5 to have the inlet valves cleaned and injectors flow tested and re-sealed.
Instagrams;
@shannon_ob
Offline GTI DAZ
  • My Ride: Previous: Mk7.5 Fiesta ST, Current: None, future: MK5 GTI
fantastic work, im planning a refresh this month for my rear subframe, swap out my old one for a rebuilt one, is it alot of work? and do you have a parts list?
Offline shannon-ob
Thank you!
Umm not really a lot of work no, having the unit and a ramp really did help.
Parts list for what man?
Instagrams;
@shannon_ob
Offline GTI DAZ
lucky bugger, I got a friend with a unit to help, was after a parts list for the build. arms, bolts bushes ect
Offline shannon-ob
It’s very helpful
Arms are the same but we’re just powder coated. Bushes were from powerflex (I’m a dealer) bolts were through Coverdale Car Parts.
Instagrams;
@shannon_ob
Offline LC5F
  • -Receive: 80
Great progress - what rear hubs are you running - still need to fit my Passat front with new Fags too!
Not too bad:
Drop the exhaust back box
Detach brake lines, handbrake cables level sensor & ABS cables
2 bolts on each side holding shock top bolts - or  - the 1 bottom bolt on each side
4 bolts on each side holding the trailing arms
4 bolts holding the subframe and down it comes
Offline shannon-ob
Thanks man.
They’re Passat rear hubs buddy.
Instagrams;
@shannon_ob
