Author Topic: Dash Heater Core  (Read 1078 times)
Offline Notch000
Dash Heater Core
« on: February 10, 2020, 03:14:11 pm »
Dash Heater Core, I've lost all heat in the dash. my mechanic spend an age unblocking my coolant system and replaced a few bit and inclusding a coolant leak on the thermostat housing. He said it was on the verge of total failure, and took server flush cycles to get sll the sh*t out. but they never bothered there holes flushing the matrix like I originally asked. They said it most likely totally buggered up as the whole system was in really bad shape from someone using water in the coolant previously.
Asides from a reverse flush is it dash out job to replace the matrix, I've read conflicting reports that it can be done from under the foot well ?? anyone have a guide link please ??? The cores themselves see cheap enough to buy.
Offline titchy
Re: Dash Heater Core
« Reply #1 on: February 10, 2020, 04:11:54 pm »
TRY YOUTUBE if the core is badly blocked its hard flush it completely
Offline muff1991
  • -Receive: 69
« Reply #2 on: February 11, 2020, 04:03:42 pm »
has your heating suddenly stopped? does your temp gauge exceed normal (90) ?
The core can be replaced without taking the dash out.
