Author Topic: 2006 2.0 TDI GT BMN - red oil light flashing  (Read 951 times)
Offline Wingz4life2788
  • Newbie
« on: February 14, 2020, 08:12:19 pm »
Bought a 2006 2.0 TDI GT BMN engine about 6 months ago.  Took it in for the red oil light flashing after I put in a new oil pressure sensor. Light still stayed on.
I brought it to a VW Audi specialist and the mechanic changed out the oil pump, oil and filter  After the first test drive (30 mins) oil light did not come on. Took it for a second test drive and light came back. He then changed oil pressure sensor changed to OEM and changed crankshaft sensor.
Light is still on.  He did a pressure check and pressure came back at correct readings. He tested witing and thinks it's a dash fault?
Any thoughts?
Sent from my SM-N960U using Tapatalk
