Author Topic: Cam Chain  (Read 1121 times)
Offline GAMO
Cam Chain
« on: February 14, 2020, 11:46:27 pm »
Has anyone fitted an after market Cam chain, tensioner an adjuster? seen this on fleabay which is much cheaper than VW/TPS
https://www.ebay.co.uk/itm/Audi-A4-2-0-TFSI-2-0-FSI-Cam-Chain-Tensioner-Sprocket-Kit-Fuel-Pump-Cam-Follower/332547005766?hash=item4d6d589d46:g:IV4AAOSwwqVcPc3o
or should i stick with genuine??
Cheers GAMO
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=7ul4ispv51mlpdj6lumsvvp4t6&/topic,19740.0.html
Re: Cam Chain
« Reply #1 on: February 15, 2020, 12:23:02 am »
Genuine. Just need to replace the chain and tensioner unless there is a known issue with the adjuster.
Re: Cam Chain
« Reply #2 on: February 15, 2020, 03:22:49 am »
A genuine VVT adjuster is knocking on the doors of £400 on it's own, so the fact the whole ebay shebang costs £239 ought to tell you something.
As above, genuine only for critical engine components.
VVT sprockets only need replacing if the oil control rings have worn deep grooves into the centre bore, which will cause lazy VVT advance/retard, or if it gets messed up when removing the Polydrive bolt.
Early engines had metal oil control rings which caused said wear grooves.  Later engines switched to plastic rings which don't eat into the metal so much.  No need to spend 400 quid + chain gear if it's not necessary.
Offline GAMO
Re: Cam Chain
« Reply #3 on: February 15, 2020, 05:33:26 pm »
Thanks for the reply's guys! TPS sell a chain and tensioner kit for 200 ill check the adjuster once it out hopefully i wont need it!
