Author Topic: Dog bone mount bush  (Read 2063 times)
Dog bone mount bush
« on: February 23, 2020, 02:46:41 am »
Thinklng of upgrading mine to these has anyone used them and are they any better than oem ones with the insert in the bush
pic url maker
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
Re: Dog bone mount bush
« Reply #1 on: February 24, 2020, 10:53:16 pm »
I’ve the similar THS full rubber mounts on mine
NVH is way too much albeit the gear changes are silky smooth (dsg)
I’m replacing very soon with OEM ones again as I can’t bear it anymore
I personally wouldn’t recommend it
« Reply #2 on: February 24, 2020, 11:00:34 pm »
Cheers for the info sort of in the same situation..was the nvh pretty bad
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #3 on: February 25, 2020, 12:33:51 am »
Lower rpm the whole car would vibrate
Honestly it’s been bugging me since I installed it but just haven’t had the time to replace it
As crazy as it may sound, I’d choose the jerky downshifts over the vibration!
Offline colesey
  • -Receive: 89
« Reply #4 on: February 25, 2020, 05:57:06 am »
I wouldn’t be using track durometer bushings on a road car...
« Reply #5 on: February 29, 2020, 01:53:15 am »
Sounds like you are a customer for a pair of new OEM side mounts + Vibratechnics dogbone.  That combination gives virtually zero increase in NVH.
The OEM mounts are actually OK for a few years, but they fall foul of the same rubber degradation that also affects tyres and chassis bushings.
« Reply #6 on: February 29, 2020, 01:08:02 pm »
Already changed the top mounts to 034 motor sport ones
Still not sure which bottom mount to go for as I don't want a lot of Nvh in the car
« Reply #7 on: March 06, 2020, 05:27:17 pm »
OEM will give the least amount of NVH and I'd say the Vibratechnics is a close second.
