September 25, 2024, 09:24:48 am
All Things Mk5
Mk5 General Area
MAF removal
Topic: MAF removal (Read 1238 times)
Aparoon
Won't Shut up.
-Given: 13
-Receive: 7
MAF removal
March 05, 2010, 01:55:07 pm »
Is it as simple as removing the 2 torx bits and pulling it out? Mine doesnt want to come out
Any help appreciated, im mid intake fitment
Chris
Edition 30 DSG, Revo 2+,BSH Intake, Autotech hpfp, Blueflame TBE, Eibach Sportlines, Speedline Turini's GONE
Greeners
Just look at my post count
-Given: 201
-Receive: 199
Re: MAF removal
Reply #1 on:
March 05, 2010, 01:58:36 pm »
Yup pretty much!
It may be a bit tight if the engine is warm but once the screws are out it should just slide out!
snapey
Won't Shut up.
-Given: 9
-Receive: 22
Re: MAF removal
Reply #2 on:
March 05, 2010, 01:58:56 pm »
Should be pal. Just give it a wiggle around in the housing and it should break it free.
If you have to ask why, you'll never understand.
Aparoon
Won't Shut up.
-Given: 13
-Receive: 7
Re: MAF removal
Reply #3 on:
March 05, 2010, 02:01:51 pm »
It wont come out! It slides out about 5mm then stops, if i look inside at the maf sensor i can see a metal ridge in the design that looks like it fouling the slot
Is it very sensitive, am i going to damage it?
Thanks for the replies
Hedge
-Given: 484
-Receive: 304
Re: MAF removal
Reply #4 on:
March 05, 2010, 02:17:48 pm »
It is possible to just unclip the cable to get things out the way and allow them to cool down.
KRL
Won't Shut up.
-Given: 25
-Receive: 29
Re: MAF removal
Reply #5 on:
March 05, 2010, 02:26:07 pm »
Once the torx screws are out it should slide out quite nicely. Like Hedge said - unclip the MAF first then you should be able to get at it more easily. Try gently rocking it up and down as you are pulling it out if it is catching.
S3 is now for sale -
http://www.mk5golfgti.co.uk/forum/index.php/topic,25046.0.html
Aparoon
Won't Shut up.
-Given: 13
-Receive: 7
Re: MAF removal
Reply #6 on:
March 05, 2010, 02:45:31 pm »
Done it
Thanks for the quick replies everyone much appreciated, sounds very good so far
going to go and fuel up and give it a run..
All Things Mk5
Mk5 General Area
MAF removal
