Author Topic: Asymmetric Tyre Advice Needed Please....  (Read 15653 times)
« on: March 05, 2010, 05:10:07 pm »
I'm currently needing to replace my third pair of Goodyear F1 Asymmetrics and have been very happy with them in both dry and extremely wet conditions. What I do is when the front pair get down to 2.5mm I transfer the rears to the front and buy a new pair for the rear axle. This is what I'm advised is best practice on FWD cars.
When I bought my first GY F1 Asymm pair they went on the rear and the GY F1 Directional pair moved to the front axle. This wasn't a good combination and I would find myself randomly subjected to twitches and snatching with the ESP interfering - Usually on fast sweeping bends (on B-roads!). After my initial scares and attempts to reproduce the same in order to understand what was going on and what I needed to do about it I adopted an aggressive 'fook it!' attitude, kept the throttle constant and drove through the problem. I think this problem may have arisen out of the asymmetric+directional mix but helpful as Goodyear Technical tried to be they had never tested their two products together on the same car.
So, I am now thinking of having a pair of Vredestein Ultrac Sessanta, which are asymmetric, and then my next change will result in the Vredy's all round. I used to use Vredestein when I raced bicycles and have always highly rated their rubber, though 18mm slicks with 150psi is a different ball game.
I know that winrya has the Vredy+GY Asymm mix at the moment without issues but if I do buy a pair of Vredy's it'll be the mix I use on my trackday in Nurdleburgering in April and I want to feel safe.
Has anyone got any experience or views about this combination, please?
« Last Edit: March 05, 2010, 05:30:53 pm by RedRobin »
Offline Poverty
  • -Given: 36
  • -Receive: 21
Re: Asymmetric Tyre Advice Needed Please....
« Reply #1 on: March 05, 2010, 05:13:38 pm »
Get R1R's, fine i standing water, and let me put down 300ponies in first with 0 wheelspin the other day. Could hear the car components creaking away though  :grin:
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
« Reply #2 on: March 05, 2010, 05:24:15 pm »
If you put the New f1s on the rear and old tyres on the front this will cause the rear to be twitchy due to the fact the rears havnt bedded in propperly yet, you are probably aware of this though.
I too run F1s and have found the same, i have also replaced the rear tyres although i expect this to vanish in 1k miles or so.
I usually run Eagle f1s on all my cars im a big fan, never ran the verdis but ive heard they are good too. I also like the contact sports.
« Last Edit: March 05, 2010, 05:26:03 pm by gobbleplease »
MK7 GTI - ARRIVING DECEMBER
Offline FamilyDub
  • ...who needs a diesel?
« Reply #3 on: March 05, 2010, 05:26:41 pm »
The fact you are asking the question means you have doubts. I'd stick with same directionality/patterns, etc.
It might mean replacing four, but surely that's cheaper than retrieving a totalled car from the 'ring...?
MKV GTI | Reflex Silver | 5-dr, Family-Spec | 17" w/anthracite Finish | Manual | Highline | Cruise | Revision 'D' DV | Dirty Pipes |
« Reply #4 on: March 05, 2010, 05:37:37 pm »
....You have missed the fact that I want to run the same tyres whether road or track without continually changing them.
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #5 on: March 05, 2010, 05:40:50 pm »
[/quote
Whats the issue, Its a tyre just like the vred. Why would you constantly need to change r1rs?
« Reply #6 on: March 05, 2010, 05:44:27 pm »
....I've never had a problem with deeper treads on the rear axle. Besides, they'd be worn in before I get there.
My plan was to buy a pair of Vredestein asymmetrics not another pair of Goodyear asymmetrics. So are you suggesting I'd be better off with the newer Vreds on the front?
Offline candy turbo
« Reply #7 on: March 05, 2010, 05:48:11 pm »
i ve just been reading about the ps3 , it gets good reviews , might be worth thinking about robin  :happy2:
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #8 on: March 05, 2010, 05:49:26 pm »
you might want to read the vreds thread over on scn. DjHorace for example wont be buying another set.
« Reply #9 on: March 05, 2010, 05:49:41 pm »
....Because the R1R is not designed as a general purpose all year tyre AFAIK and furthermore the wear rate is (IIRC) much worse. It's doubtless a great tyre but somewhat more specialist.
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #10 on: March 05, 2010, 05:50:47 pm »
So you are after VFM....How odd  :grin:
Offline winrya
« Reply #11 on: March 05, 2010, 05:54:18 pm »
I did a lot of research and came across the guy above but he's pretty much the only negative user i found.  The americans for example are waiting 6 weeks at a time for deliveries and raving about them.  I had some bad experience with ps2's and wouldn't buy them again but many think they are the best tyre out there, so you need to take alot of opinions with a pinch of salt.
« Reply #12 on: March 05, 2010, 05:54:58 pm »
....Where abouts would that be please?
« Reply #13 on: March 05, 2010, 06:00:02 pm »
....I've never been a fan of Michelins.
I certainly do need to take a lot of opinions with a pinch of salt and especially when they come from those Cupra boys.
So, are you running your Vreds on front or rear axle? Are you planning to be Vreds all round when the GY's need replacing?  You're the only guy I know so far who has direct experience so I value your opinion.
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #14 on: March 05, 2010, 06:01:59 pm »
http://www.seatcupra.net/forums/showthread.php?t=229804&highlight=camskill+sessanta
Quote
The badge certainly makes us inferior.  :stupid:
