Author Topic: Magnetic number plate fixing  (Read 37680 times)
Re: Magnetic number plate fixing
« Reply #15 on: September 16, 2010, 09:20:53 pm »
I would try VRSapples sheets. They look good, but you might struggle with alignment, because the whole plate will be magnetic. shouldn't be a problem if you cut into small squares.  :smiley:
I am on Version 3 or 4 at the minute  :grin: I found the magnets would pull off after time, and the alu sheets wouldn't hold to the plate. Finally figured out it was because the mask is curved. so on my last one i glued the alu strips on, then clamped it to the mask until the glue had gone off. This seems to have solved my problems now as my plate has a permanent curve, the same as the mask.  :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #16 on: September 17, 2010, 07:18:23 am »
afrogti
« Reply #17 on: December 19, 2010, 09:43:06 am »
Awesome guide TC should come in handy for me soon
Offline Jayy26
« Reply #18 on: September 23, 2015, 03:17:45 pm »
anyone know which magnets were used,as they is a fair few choices haha
thanks
Offline Stooey
« Reply #19 on: September 26, 2015, 10:30:27 am »
thanks
I have also done this and I used n52 magnets, there meant to be the strongest vairiation of these magnets, and I have had no problems at all
