Author Topic: Cdl swap  (Read 908 times)
Offline Bradleydw94
  • Newbie
  • CDL SWAPPED GTI
Cdl swap
« on: March 11, 2020, 04:46:17 pm »
Sorry if I've posted in the wrong place.
I recently done a cdl swap from bwa now got it all back together and the car just won't send a spark to the coils.
Turns over perfect got compression at all cylinders but can't figure out why it won't work.
No fault codes
Offline muff1991
  • -Receive: 69
Re: Cdl swap
« Reply #1 on: March 12, 2020, 04:43:11 pm »
Was the CDL running fine before you put it in?
are you getting power to the coil plugs? did you use your loom or the CDL loom (im not sure if they're different tbh)
maybe list everything you've done then people might be able to point you in a direction rather than clutching at straws.  :happy2:
Offline Bradleydw94
  • Newbie
  • CDL SWAPPED GTI
Re: Cdl swap
« Reply #2 on: March 14, 2020, 09:33:32 am »
Running the cdl loom it was running before it was put in.
No power to the coil plugs.
Checked fuses crank sensors
Tried 2 ecus
