November 17, 2024, 06:32:44 pm
All Things Mk5
Mk5 General Area
Clutch dropped - leaking hydraulic fluid
Topic: Clutch dropped - leaking hydraulic fluid (Read 1058 times)
Brad_ED30
Just Arrived
-Given: 2
-Receive: 0
March 16, 2020, 06:53:38 pm »
Evening,
Cars broke down tonight with the clutch dropping to the floor and leaking hydraulic fluid.
I have the aks tuning braided line fitted which was installed along with the helix clutch kit a couple of years ago.
I’ve found this fitting disconnected and I’m wondering if it’s a simple fix of bleeding the slave cylinder?
https://www.akstuning.co.uk/aks/255-aks-braided-clutch-line.html
Currently in the recovery truck on the way to a garage so can’t post photos but the link above for aks tuning shows the fitting in the second image as a silver push fitting.
Any help would be appreciated.
Brad
LC5F
Just look at my post count
-Given: 16
-Receive: 80
Re: Clutch dropped - leaking hydraulic fluid
Reply #1 on:
March 16, 2020, 07:07:35 pm »
if its un-done itself I would be looking into the cause - hopefully its just a simple fix
Clutch bleeding can be a PITA - best to back bleed from bottom so you are not fighting air - or give the headache to the garage
Brad_ED30
Just Arrived
-Given: 2
-Receive: 0
Reply #2 on:
March 16, 2020, 08:53:50 pm »
UPDATE:
Its the bleeder valve that has popped off whilst remaining connected to the braided clutch line..
All Things Mk5
Mk5 General Area
