Author Topic: B6 Passat hubs and lower arms  (Read 1868 times)
Offline oak_grun
« on: March 28, 2020, 08:35:52 pm »
Hi, did all B6 Passats have alloy hubs and lower arms? Looking to purchase off a 55 plate tdi.
Thankd :happy2:
Offline colesey
  • -Receive: 89
Re: B6 Passat hubs and lower arms
« Reply #1 on: March 29, 2020, 08:41:22 am »
Yes they do. You will also need longer caliper bolts and collared nuts for tie rods / ball joints
Offline oak_grun
« Reply #2 on: March 29, 2020, 09:26:06 am »
Thanks. I'm running TTRS calipers with 340mm TTS discs. I'll be replacing ball joints for new. Do I buy passat ball joints?
Thanks :happy2:
Offline colesey
  • -Receive: 89
« Reply #3 on: March 29, 2020, 02:19:34 pm »
I think you can reuse the existing ball joints however I had the Superpro ones fitted at the same time for extra camber and corrected roll centre for lowered suspension. Wheel alignments are pretty pricey so may as well get as much work out of the way at the same time.
