Author Topic: Wheel advice  (Read 3373 times)
Offline matsu
  • -Given: 78
Re: Wheel advice
« Reply #15 on: March 07, 2010, 12:34:36 am »
To b honest if I had known what agg new wheels can b I might not have bothered. But it's all down to research and for mr .... Lesson learnt
matsu
Offline Smudgster
Re: Wheel advice
« Reply #16 on: March 07, 2010, 07:32:41 am »
Are we saying that the harsh ride etc will be the same with all 19" wheels
Got any good wheels sites so i can have a gander
« Last Edit: March 07, 2010, 08:41:50 am by Smudgster »
Offline big al
Re: Wheel advice
« Reply #17 on: March 16, 2010, 10:22:50 am »
^^^^^^ I think the Interlagos are 8''
They should fit really unless there is ridiculous offset.  :chicken:
Got the Interlagos off at the weekend, 8.0jX18H2, ET41, Not quite sure what all that means, but if I do put any smaller than 235 will this stop the rubbing on the arches?
Re: Wheel advice
« Reply #18 on: March 16, 2010, 10:48:33 am »
That spec would make it about 16 mil more poke than a Monza, so i can see why you are getting rubing under compression.
If you go down a tyre size to 225 this will help a bit, but i reckon you will still get rubbing especially if you have only installed springs.  :happy2:
Offline tony_danza
  • -Receive: 112
Re: Wheel advice
« Reply #19 on: March 16, 2010, 10:59:15 am »
Mine are 18x8ET42 and don't rub the rears on a 225 - I think the tyre swap will cure it, don't forget a 235 is a bit taller in profile too (40 is a ratio, not a measurement)
Sideways yo!
