Author Topic: ISSUE - Revs climbing when changing gear (Video Attached)  (Read 2853 times)
Offline Mayney
« on: April 07, 2020, 04:06:13 pm »
Hi all,
New issue has arisen on my car today... the revs seem to climb when inbetween changing gears (Clutch pressed) meaning its very hard to change smoothly unless i wait around 3-5 seconds for the revs to dip again.
The issue seems to worsen (revs climb more) with more throttle input. It tends to become noticeable when going above 2000rpm. I have attached a video demonstrating the issue.
The car is R Tech 2+ spec. PCV is deleted and this issue wasnt present a few days ago.
&feature=youtu.be
Anyone have any ideas on the cause of this? I was thinking maybe breather or throttle body related?
« Last Edit: April 07, 2020, 05:28:13 pm by Mayney »
Offline Mayney
Re: ISSUE - Revs climbing when changing gear (Video Attached)
« Reply #1 on: April 12, 2020, 12:59:15 pm »
To add/clarify to this..
The revs rise in between gear changes (OFF Throttle/ Clutch depresses) The rise in revs seems to depend on how much throttle was being applied in the build up to coming off throttle.
The exhaust note seems a but different.. And the boost does not come in linear like it usually would. Throttle inputs between 25-75% seem very jerky almost like it cant decide how much boost.
Ideally i need to log in VCDS but until the lockdown is finished this seems unlikely... any ideas are appreciated :)
Offline Mayney
« Reply #2 on: May 12, 2020, 03:36:17 pm »
Scanned it and had a clutch switch related fault. Ordered the new "hall" sensor as VW call it. Will keep posted.
Offline Mayney
« Reply #3 on: May 15, 2020, 03:52:29 pm »
New hall sensor/switch and a 5A Fuse in engine bay F39 has fixed the issue!
Offline muff1991
  • -Receive: 69
« Reply #4 on: May 16, 2020, 10:54:52 am »
Glad you fixed it mate, read the title and thought clutch switch straight away.
This used to happen on the mk4’s too and was related to the coolant temp sensor.
