Can only be done via vcds. but if you have access to vcds then its in controller 37 navigation byte7 bit 4-5 the selection is either premium, highline or sportline the highline is what you have on now the premium is the reverse to that and the one you want is sportline the red/black.
Darren
I eventually got myself VCDS and tried to change the display setting via the long coding, I can see the option to change between trhe 3 options and it says coding has been accepted, however the display is still the same.
I ran a scan and there are some faults logged under nav /radio:
VCDS Version: Release 908.2
Data version: 20100326
Wednesday,26,May,2010,21:45:03:08280
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 77
VIN: WVWZZZ1KZ7W283357 Mileage: 55320km/34374miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 L HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0030
Revision: 5BH16--- Serial number: VWZ7Z0G8150775
Coding: 0403000318070160
Shop #: WSC 78905 027 444167
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
Shop #: WSC 01279 785 00200
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BN HW: 1K0 907 044 BN
Component: ClimatronicPQ35 110 1010
Revision: 00110021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000007056844
Coding: E78F8F2700041500471400001400000000087F075C0001
Shop #: WSC 00000 785 00200
Part No: 1K2 955 119 E
Component: Wischer 040507 021 0501
Coding: 00038805
Shop #: WSC 00000
Part No: 1K0 955 559 AB
Component: RLS 100507 020 0105
Coding: 00208933
Shop #: WSC 00000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD17GBUS
Coding: 0013112
Shop #: WSC 01269 785 00200
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000042
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K6 920 973 HW: 1K6 920 973
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0G8150775
Coding: 0007403
Shop #: WSC 00488 210 71781
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 080507F1000576
Coding: 7D0F03C807000001
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VDD 1610
Address 37: Navigation (J0506) Labels: 1T0-035-680.lbl
Part No SW: 1T0 035 680 C HW: 1T0 035 680 A
Component: RNS-MID H04 2660
Revision: AB001001 Serial number: VWZ6Z7H6010110
Coding: 000004000400001200
Shop #: WSC 05314 000 00000
ASAM Dataset: ------------------------- ------
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 46
Mileage: 48436 km
Time Indication: 0
Date: 2000.00.00
Time: 19:53:09
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0984
Coding: 0000564
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Shop #: WSC 00000 028 00001
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 919002085103087F2D040F0F70085AC690BC00
Shop #: WSC 00705 210 60120
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000564
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
Address 56: Radio (J0506) Labels: 1T0-035-680.lbl
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 46
Mileage: 48436 km
Time Indication: 0
Date: 2000.00.00
Time: 19:53:09
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 B HW: 1Z0 035 729 B
Component: FSE_2P7x H31 0050
Revision: 00000001 Serial number: 00000005006502
Coding: 0000402
End ---------------------------------------------------------------------
Any ideas anyone?
