Author Topic: Mk5 got tdi no boost after fitting new cluch and flywheel  (Read 1015 times)
Offline Darylfife
  • Newbie
« on: April 19, 2020, 03:35:37 pm »
Hey any help appreciated
Today I fitted a new clutch and flywheel to my mk5 golf gt tdi
For some reason since doing this I have no boost car sounds like it’s struggling can’t see any sensors unplugged or any obvious boost leaks ect
Car was running fine before apart from clutch being away any help much appreciated
Offline chimp400
  • -Given: 46
Re: Mk5 got tdi no boost after fitting new cluch and flywheel
« Reply #1 on: April 20, 2020, 10:30:21 am »
Has to be related to the strip down if it was fine before.
Are you sure no wires were trapped when putting the box back in?
« Reply #2 on: April 20, 2020, 10:47:42 am »
 Is one of the boost pipes not in correctly.. Double check everything
Offline Stupots
  • -Given: 18
« Reply #3 on: April 22, 2020, 01:50:06 pm »
It's got to be a boost pipe popped out, surely. Probably lower near side just in front of the gearbox?
