Author Topic: Post your Nordschleife lap times here  (Read 42124 times)
Offline jhtrophy
  • Oh no it's a diesel
Re: Post your Nordschleife lap times here
« Reply #30 on: March 13, 2010, 03:11:45 pm »
Should be mate. A focus rs and r26r are in late 7s stock so a well set up ed should
« Reply #31 on: March 13, 2010, 04:44:24 pm »
I'm assuming that is bridge to gantry?
I thought the FWD record for the full lap was 8'16.9" by an R26R.
Offline jhtrophy
« Reply #32 on: March 13, 2010, 07:13:31 pm »
yeah mate, the full lap is about 30 sec longer , so on paper, both the rs and meg would be in late 7s. my target is still 8 min 30, but 12 sec off last time there :sad1: may try with 888s, but not sure if will get there this year.
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
« Reply #33 on: March 15, 2010, 09:44:41 pm »
Holy F*ck those are bloddy quick times, ill be aiming for about 9.40 with standard power and i thought that would be a good time !
MK7 GTI - ARRIVING DECEMBER
Offline jhtrophy
« Reply #34 on: March 16, 2010, 07:05:55 pm »
times just fall with puttin in the laps mate, you just hit a point where you stop enjoying it as you chase the times, people dont get out of way so your lap feels spoilt, you end up forgeting your there to have fun!!! would not bother with stopwatch and just enjoy driving it, i never did until my girlfriend timed it without telling me, was a 9min 5sec i think, and i thought i would be in 10s, so ended up trying.
Offline laurent.d
« Reply #35 on: June 30, 2010, 10:27:12 pm »
Last best lap time 8'39''5 whith some trafic and I wasn't in fast lap mood.
My theoric lap time is 8'29''5, I hope I could do it in real soon.
A3 2.0 tfsi DSG S-Line/VWR K04 Turbo kit/Engine Revo Stg 3/Milltek Exhaust/DSG Revo Stg 2/Quaife LSD/Bilstein PSS10/H&R sway bars/Power Grip Morego/VWR Suspension Bushes/VF Engineering Engine Mounts/VWR Lower Mount/OZ Ultraleggera 8x18 ET45/Brembo 328x28 2pcs 4 pot ''A'' caliper/Braille Battery
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #36 on: June 30, 2010, 11:06:24 pm »
i did 9 laps over 2 days in may 2010, best time was 9.46 min.
Over the top mod list ;o)
« Reply #37 on: July 08, 2010, 12:37:18 pm »
My best lap so far B to G is an 8:26  :happy2:
« Reply #38 on: July 08, 2010, 01:00:41 pm »
yehha! thats an awesome lap!
Offline laurent.d
« Reply #39 on: July 08, 2010, 09:54:51 pm »
Good lap time :happy2: :congrats:
Offline laurent.d
« Reply #40 on: July 26, 2010, 12:07:44 pm »
last best lap time BtG this weekend:
8'32''2 with a best theoricl lap in 8'24''5
  • -Given: 243
  • -Receive: 154
« Reply #41 on: July 26, 2010, 02:05:57 pm »
excellent time, how was your alignment to drive with??  :drinking:
Offline laurent.d
« Reply #42 on: July 26, 2010, 09:00:09 pm »
Thanks danishmkvgti
As I wrote here http://www.mk5golfgti.co.uk/forum/index.php/topic,16370.msg242964.html#msg242964
My car has been aligned in France at these values:
Front:
Caster     L 7°35'    R 7°41'
Camber   L -2°17'   R -2°04'
Toe         L +0°10'    R +0°10'
Rear:
Camber   L -1°56'   R -1°51'
Toe         L +0°05'    R +0°05'
The car is stable enough at high speed and when you jump on the brakes while cornering.
But still, the rear and turns nicely around corner.
I will go the next time for a tiny less front Toe in for a little bit more aggressive turn-in.
The turn-in seems a little bit sticky right now
As said Tony_danza,  about 0°07' each side.
I will also again reduce rear and camber to around -1°40' instead off -1°50'
Parallel Toe at the rear is too alive and loose for me,  I prefer a little bit more stability.
« Last Edit: July 26, 2010, 09:05:20 pm by laurent.d »
Offline fuscobal
  • -Receive: 27
« Reply #43 on: July 27, 2010, 07:21:26 am »
How could you set the front camber to such high values since it can't be done with the OEM setup ?
Mk5 GTI 6MT - Revo stage 3
Offline laurent.d
« Reply #44 on: July 27, 2010, 08:03:56 am »
Hi Fuscobal!
Because I have got 10mm extended Morego wishbones which give 20mm wider track and 1°30' more négative camber. That is why I have got 2°10' of negativ camber.
It doesn't look High-tech but gives more camber than TT arms and works very welll.
