Author Topic: autolock  (Read 4871 times)
Offline TOONARMY
Re: autolock
« Reply #15 on: March 11, 2010, 09:29:31 pm »
When there's a pool of water in your light, i can assure you its covered under warranty
Condensation and water ingress are 2 different things. If its water ingressing into the light unit, then yes it will be coverd. If it is purely due to condensation in the light unit and the fault is not due to a manufacuring defect, then it will not be coverd, there is a TPI avalible for this fault. If they do cover it, then it will be rejected.
toon
Offline Matt23
Re: autolock
« Reply #16 on: March 11, 2010, 09:43:08 pm »
The condensation in rear lights seems to be a common problem as i bought some R32 rear lights from the dealer last week and i was told to keep hold of my receipt as condensation was a problem and they have been replacing them under warrenty.
