Author Topic: Gateway / canbus  (Read 2368 times)
Offline SamwiseG
Gateway / canbus
« on: May 04, 2020, 01:13:36 pm »
I have recently installed an rcd330 into my 2006 golf and I now having a battery drain issue. Does anyone here have a pre coded canbus I could buy or know where I can get one pre coded to stop this issues ?
Cheers sam
Offline PirelliAu
Re: Gateway / canbus
« Reply #1 on: May 04, 2020, 03:43:05 pm »
I have the same issue and have had it ever since I bought the car with the rcd330 installed. How do you get rid of it? I miss being able to listen to music in my car without having to turn on the engine for a good hour in my old 2007 outlander haha
Offline SamwiseG
« Reply #2 on: May 04, 2020, 08:11:36 pm »
I’m not sure, if i find a solution I will let you know. Hopefully someone can point us in the right direction  :smiley:
« Reply #3 on: May 05, 2020, 12:59:58 pm »
you should be able to get a correctly coded canbus provided you can tell the seller what the original configuration of the car hardware is. This unfortunately may mean a vcds scan to see what modules your car has installed so that info can be coded to the new canbus.
whereabouts are you as there is a list of members with vcds who may be able to do a scan in the vcds forum here.
Offline LC5F
  • -Receive: 80
« Reply #4 on: May 05, 2020, 04:10:54 pm »
The short term quick fix is changing the power to ignition os outlined here:
https://www.mk5golfgti.co.uk/forum/index.php?topic=37977.0
Offline SamwiseG
« Reply #5 on: May 06, 2020, 10:18:08 am »
Thanks for your replies everyone, I am in Norwich @bacillus , I don’t have the equipment to do this myself, if you know of anyone that would be great. I have spoken to a couple vw specialist garages and they’ve quoted me around £100 to get the canbus updated but have said it will be more if I need a newer canbus.
« Reply #6 on: May 06, 2020, 11:52:12 am »
look to see if anyone in your area  on this thread can help, https://www.mk5golfgti.co.uk/forum/index.php/topic,88875.0.html
If you plan to fit yourself (it's a pain for most) then see if anyone with vcds on the list can help take a scan to see what modules are installed. Get a printout or made a note of what's installed.
You can then install an uncoded newer canbus (it can be an used coded one as well) then get it coded using vcds. that part is easy to do if you've had an original vcds scan.
hth
Offline SamwiseG
« Reply #7 on: May 06, 2020, 12:41:22 pm »
Thanks @bacillus. I am still very unsure with what do do. I don’t really under grand scanning as I don’t have the equipment so I’ll check in the thread. Thank you so much for you help it’s much appreciated
Offline LC5F
  • -Receive: 80
« Reply #8 on: May 06, 2020, 04:19:50 pm »
You will need a new canbus, the issue is your current canbus does not know how to power down your new head unit.
The job is only half an hour so £100 sounds a bit steep
Offline SamwiseG
« Reply #9 on: May 06, 2020, 10:29:43 pm »
@LC5F oh I see now that makes sense. would a canbus out of a mk6 do the job ? And then just find a garage to copy my cars config over to the new one do the job ?
Offline Dannyboi#722
  • My Ride: GOLF GTI EDITION 30 TTE480 BHP 446 & 443FT*LB FORGED (Mapped by R-Tech)
« Reply #10 on: May 06, 2020, 11:58:17 pm »
Sam drop me a message with your number as can’t dm you 👍
Offline SamwiseG
« Reply #11 on: May 07, 2020, 11:25:58 am »
@Dannyboi#722 have you got any socials I can get you on to send my number mate ?
« Reply #12 on: May 07, 2020, 11:53:56 am »
Here’s my number 07548507841 give us a call. @SamwiseG
Offline LC5F
  • -Receive: 80
« Reply #13 on: May 07, 2020, 05:15:57 pm »
Yes - lots of stuff online - but Dannyboy should sort you out
Offline burtz
« Reply #14 on: May 09, 2020, 10:03:15 am »
I was under the impression if you buy a Rev L or newer canbus, you can just plug it straight it and it would work? Or do they always need coding? I'm a bit confused lol
