Author Topic: Newbie with a temperamental MKV  (Read 1279 times)
Offline p4cks
  • Newbie
« on: May 09, 2020, 03:26:36 pm »
Had the car a couple of weeks, however the lack of cruise and auto lights annoyed me so I set about changing them. The CC install I followed the very helpful volkswizard guide on YouTube and the coding was accepted on the Steering and Engine modules but to no avail... CC not working.
The Chinese light switch also throws up a code.
Up to now I've changed the PCV valve and Diverter Valve at the weekend and I'm waiting on a set of four coil packs and spark plugs
I'm at a loss what the error codes are, and what's needed to fix them. Can anyone help?
Below are the error codes from my scan using VCDS:
Saturday,09,May,2020,15:14:22:00009
VCDS Version: 20.4.1.0 (x64)
www.Ross-Tech.com
VIN: WVWZZZ1KZ5W210324   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ5W210324   Mileage: 178580km-110964miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Not registered 0001
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels:. 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115     HW: 1K0 907 115
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0E1497193
   Coding: 0403000318070160
   Shop #: WSC 00764 210 84339
   VCID: 63C51A8BA255B19E76-8036
1 Fault Found:
001384 - Cruise Control Switch (E45)
               P0568 - 002 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 178587 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:10:41
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 89.0°C
                    Temperature: 55.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.684 V
Readiness: 0110 0100
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 3A7B87EF755F905605-806E
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AF
   Component: ClimatronicPQ35 066 0505
   Shop #: WSC 00000 000 00000
   VCID: 6BD572AB4A85F9DECE-803E
2 Faults Found:
00797 - Sunlight Photo Sensor (G107)
            010 - Open or Short to Plus
00709 - Sunlight Photosensor 2 (G134)
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001432240
   Coding: E58D0F0600041800001400001400000000087F075C
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00218142
   Shop #: WSC 00000
1 Fault Found:
01800 - Light Switch (E1)
            008 - Implausible Signal
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 C    HW: 1K0 909 605 C
   Component: 08 AIRBAG VW8   013 2100
   Revision: 02013000    Serial number: 0033HD05RK46
   Coding: 0012344
   Shop #: WSC 01269 785 00200
   VCID: 2C57B1B78F0B3EE687-8078
   Subsystem 1 - Serial number: 6332MSME09293F09I
   Subsystem 2 - Serial number: 6342MSME09293A47G
   Subsystem 3 - Serial number: 6351HSME06224864%
   Subsystem 4 - Serial number: 6361HSME060848172
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksäulenmodul 521 0050
   Coding: 0000042
   VCID: 356194D35C417F2EE8-8060
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 960 D
   Component: KOMBIINSTRUMENT VDD 0812
   Coding: 0000403
   Shop #: WSC 00083 067 57207
   VCID: 306FA5C7A3235A06BB-8064
Address 19: CAN Gateway        Labels:. 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H11 0110
   Revision: 11          Serial number: 290010520400D4
   Coding: 3D3F0340070003
   VCID: 295948A380F92BCE7C-807C
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 254
                    Reset counter: 125
                    Mileage: 168383 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 02:23:49
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0812
Address 37: Navigation        Labels: 1K0-919-887-MFD2.lbl
   Part No: 1K0 919 887 B
   Component:      Navigation     0001
   Coding: 0000101
   VCID: 387F9DE74B538246F3-806C
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0168
   Coding: 0000052
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V2.clb
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.12      1502
   VCID: 3169A0C3A829530EB4-8064
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 19C802087F2D850F485FC69010CC
   Shop #: WSC 12345 785 00200
   VCID: 79F958E330D95B4E4C-802C
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H02 1301
   Subsystem 2 - Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Subsystem 3 - Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Component: Tuersteuergeraet 09 0120
   Coding: 0000052
Address 56: Radio        Labels: 1K0-035-095.lbl
   Part No: 1K0 035 095
   Component:        Radio        0001
   Coding: 0010400
   VCID: 62CB1F8FBD4FB8967D-8036
1 Fault Found:
00871 - Bass Speaker Front Right (R23)
            011 - Open Circuit - Intermittent
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0217
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
End-------------------------(Elapsed Time: 01:44)--------------------------
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: Newbie with a temperamental MKV
« Reply #1 on: May 10, 2020, 08:44:31 pm »
Address 19 shows the coding incorrect. Although the coding appeared to be accepted when you dd it, it was likely not correct. I am no coding expert so, if you didn't copy and save the original coding...I believe VCDS has a reset or debug coding if there's not another way to do so. You could try the VCDS forum on Ross-Tech's site.
Offline Dannyboi#722
  • My Ride: GOLF GTI EDITION 30 TTE480 BHP 446 & 443FT*LB FORGED (Mapped by R-Tech)
« Reply #2 on: May 11, 2020, 07:52:28 am »
@p4cks fault code P0568 is usually the cruise control switch on stalk.
AUTO HAVC
There’s a sensor in the middle of dashboard which looks like a speaker cover remove it and have look to see if it’s plugged in. If it is then you’ve possibly got a faulty sensor. I’m sure you can do an output test on it with you vcds.
19 CAN GATEWAY.
Fault code is related to your radio In the installation list you will need to put a tick in one of the boxes both radio & satellite Navigation need ticking. Clear fault codes.
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #3 on: May 11, 2020, 10:24:00 am »
Post your VCDS output on the Ross Tech website. not only will you get the makers of the software telling you what the codes mean but sometimes people who had resolved those same codes.
Offline p4cks
  • Newbie
« Reply #4 on: May 12, 2020, 07:18:29 am »
AUTO HAVC
19 CAN GATEWAY.
Thanks for this. The HVAC one makes sense as I replaced the mesh grille with the coin tray to stop the rattling and there was nothing to plug that plug into! Wonder how I'll fix the error message?
The CAN-BUS one is sorted now, so thank you also for that.
The light switch is still an issue so hopefully the seller will send me another one out and it'll be fixed.
Front speaker I'm not that arsed about.
I've also now got a P0234 which points to a duff Boost Control Valve (N75) so I've ordered one of those. Strangely enough this error code is often thrown up on remapped cars and I must say that this GTI is quicker than the other two I've had by some margin so either both of those were f*cked, or this one has had some work done to it. Time will tell I suppose.
Cruise control stalk was retrofitted by me, however I didn't check for the wire that some cars have and some don't so I'll have to take it all apart at the weekend to check if it's there and if not, buy and fit a new wire. What a f*ck on!
