Author Topic: k04 dv housing  (Read 910 times)
Offline Dunkdafunk
k04 dv housing
« on: May 13, 2020, 06:22:52 pm »
The k04 064 compressor housing has the dv port blanked off. Has anybody milled out this location for a direct mounted dv like those found on the k03's?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=7bqion3iluosagmqblmsfoil6q&/topic,19740.0.html
Re: k04 dv housing
« Reply #1 on: May 13, 2020, 08:39:13 pm »
Why? It's better to have the DV mounted as per the normal K04 setup.
Offline Dunkdafunk
Re: k04 dv housing
« Reply #2 on: May 13, 2020, 09:13:18 pm »
Few reasons.
1: it doesn't cost me anything to mill it out.
2: removes extra charge piping volume to allow for faster boost response
3; charge air pressure is directed directly at the compressor wheel which helps keep the turbo spooled upon lifting the throttle, minimizing turbo lag.
Re: k04 dv housing
« Reply #3 on: May 13, 2020, 09:55:11 pm »
Few reasons.
Mill it out then!  :happy2:
Re: k04 dv housing
« Reply #4 on: May 13, 2020, 10:51:16 pm »
