Author Topic: Boost gauge  (Read 1695 times)
Offline J66hhr
Boost gauge
« on: May 16, 2020, 07:47:48 pm »
Few questions on boost gauges if anyones got any experience with them
Is it worth spending £90 or so on a newsouth boost gauge or will a cheaper ebay gauge do the same job?
Also ive got automatic headlights does anyone know which wires(colours) i can tap into so the gauge lights up with my headlights or sidelights..
Lastly whats the max boost pressure you would expect on a k03.
Mk5 gti
Offline GPem3:16
Re: Boost gauge
« Reply #1 on: July 02, 2020, 03:59:18 pm »
This is my set up ed30 #0627
Drivers side vent pod ebay £9
Cheap gauge ebay with led switch £12
Boost tap ebay £15
 (Would add a photo If I kbew how  :thinking:)
« Last Edit: July 02, 2020, 04:01:54 pm by GPem3:16 »
Offline J66hhr
Re: Boost gauge
« Reply #2 on: July 02, 2020, 05:49:38 pm »
Boost tap ebay £15
Ended up with the new south and a coloumn from awesome gti
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Re: Boost gauge
« Reply #3 on: July 02, 2020, 05:59:33 pm »
i have both oil pressure and oil temp gauges from Newsouth. The blue leds in them is quite a close match to the rest of the instruments. I still needed to buy a couple of bits to fit them, and that was after checking with Awesome that the gauges came with everything.
The black circular trim around the gauges are not secured so do occasionally do fall out. I'd give them a 6/10 as they are pricey but not very well made and the colour of the leds in not correct.
Offline GPem3:16
Re: Boost gauge
« Reply #4 on: July 02, 2020, 06:12:02 pm »
Nice. I looked at that but diddnt want to spen a fortune
Sent from my SM-G955F using Tapatalk
Offline J66hhr
Re: Boost gauge
« Reply #5 on: July 02, 2020, 06:50:37 pm »
Good enough mate as long as it does the job also looks perfectly fitted.. save where u can
