Author Topic: Changed battery now everything on passenger side doesn't work  (Read 1230 times)
Offline crashdesk
  • -Given: 35
Hi,
I changed the battery yesterday. After changing there were a bunch of lights on the dashboard; Drove for a bit and everything is grand. Only major issue is, everything on passenger side of car doesn't work. Includes...
Indicators
Windows
Doors not locking
Anywhere I go I have to park tight against a wall lol
Anyone have this happen or know what it may be before I go to a mechanic/electrics specialist?
CD
« Last Edit: May 22, 2020, 07:48:57 pm by crashdesk »
Re: Changed battery now everything on passenger side doesn't work
« Reply #1 on: May 22, 2020, 08:39:07 pm »
Pull the battery negative lead again, but leave it disconnected for at least 30 mins, preferably an hour +.  Sounds bizarre I know, but I had exactly the same issue on mine and that solved it.
Or if you're feeling brave, you can pull the battery negative and positive leads and touch them together.  This will dump any capacitive charge and completely reset everything.
Offline crashdesk
  • -Given: 35
« Reply #2 on: May 22, 2020, 09:49:22 pm »
Cheers mate. Will try the first option tomorrow. Think I’ll leave the latter ;-)
Offline crashdesk
  • -Given: 35
« Reply #3 on: May 23, 2020, 02:03:41 pm »
Just did it and it worked a treat. All good! Cheers!!!!
« Reply #4 on: May 23, 2020, 09:43:14 pm »
