Author Topic: MFSW Part number check please.  (Read 2451 times)
Offline GTI 500
« on: May 23, 2020, 10:50:45 am »
Hi Guys, just need a little help/advise, i have a MK5 GTI 2005, going to fit a mfsw,just want to check part numbers for the parts i need to get/fit.
Air bag loom  1k0 971 584 C
Clock spring  1K0 959 653 C
Control unit  1K0 953 549 AJ or CH,
Can you guys confirm these are correct.
Thanks.
Offline terrier
  • -Receive: 39
  • My Ride: GTI now gone
Re: MFSW Part number check please.
« Reply #1 on: May 23, 2020, 06:27:15 pm »
Air bag loom  1k0 971 584 C .. Yes the one with the black plug for the controls :happy2:
Clock spring  1K0 959 653 C … Yes :happy2:
Control unit  1K0 953 549 AJ or CH,...Yes  I used the CH as it was easy to get hold of :happy2:
Can you guys confirm these are correct..... If fitting a MK5GTI wheel :wink:
Thanks.
  Make sure you have vcds to sort the coding
Offline GTI 500
« Reply #2 on: June 08, 2020, 09:02:25 am »
Thanks for the reply terrier .
Offline PROSEAL
« Reply #3 on: June 08, 2020, 12:15:36 pm »
What wheel are using MK5 or MK6?  Looking at doing for my 2008 GTi.  Have the loom and bought the MFSW buttons (OEM) only to realise that you cant retrofit on to an existing GTi steering with (non-DSG) No where to screw them.  So if anybody on here as non-MFSW steering wheel with DSG, I have the buttons, module and airbag loom to convert their car for sale...
Offline GTI 500
« Reply #4 on: June 18, 2020, 07:44:37 am »
Got hold of an Edition 30 mfsw, non DSG.
Offline LC5F
  • -Receive: 80
« Reply #5 on: June 18, 2020, 10:51:16 am »
The screw holes are there, just covered by plastic, you need to trim back
Go to page 4 for pics in this link: https://www.mk5golfgti.co.uk/forum/index.php/topic,95667.45.html
Offline GTI 500
« Reply #6 on: June 21, 2020, 10:57:22 am »
Fitted the CH control unit, car already had the correct slip ring (1K0 959 653 C) fitted the 1K0 971 584 C air bag loom, and coded, all buttons working but no horn & was unable to turn ESP & tyre warning lights off even after driving the car?
Put the original air bag loom back on & horn works & lights go out??
Any ideas??
Offline shoaybmakda
  • -Receive: 54
« Reply #7 on: June 21, 2020, 09:52:04 pm »
How do you check what controller you have?
Offline terrier
  • -Receive: 39
« Reply #8 on: June 21, 2020, 10:09:04 pm »
vcds scan
Offline Octoparrot
  • -Receive: 102
« Reply #9 on: June 21, 2020, 10:32:50 pm »
Any ideas??
Did you perform the steering adaptation after fitting?
Offline shoaybmakda
  • -Receive: 54
« Reply #10 on: June 22, 2020, 01:35:26 am »
vcds scan
@terrier Sorry to be thick but where would I check in vcds?
Offline GVK
  • -Receive: 68
    • GVKmotorsport
« Reply #11 on: June 22, 2020, 02:44:57 am »
Do a full scan (Auto scan) and in each section it gives part numbers/ coding for each module.
After you do a full scan it should be saved into your VCDS folder under 'scans'
scan by GVKmotorsport, on Flickr
« Last Edit: June 22, 2020, 04:31:15 am by GVK »
Offline shoaybmakda
  • -Receive: 54
« Reply #12 on: June 22, 2020, 02:33:12 pm »
thanks @GVK - so the controller number is 1k0953549BC in that case? (obviously mine may be different - will scan and check!)
Offline GVK
  • -Receive: 68
    • GVKmotorsport
« Reply #13 on: June 22, 2020, 08:24:45 pm »
Yes that's my car's scan (Mine is billy-basic,no MFSW)
« Last Edit: June 23, 2020, 01:31:57 am by GVK »
