Author Topic: Edition 30 rear brakes - Part 2  (Read 1133 times)
Offline agmac
« on: May 25, 2020, 10:04:08 pm »
Thanks all for the advice on getting the caliper carriers off. A 3ft bar on the M14 socket did the trick. No need for hitting anything, just brute force. Now that the brakes are all off, I need to replace the dust plates that sit behind the disks which have rusted though at the mounting points - one side gone and the other side going. I'd include a photo but can't work out how to.   Anybody got any hand hints on how to change these without either cutting them or taking the hub assembly off? A couple of neat cuts to slot it over the hub would be my preferred option at the moment and maybe rivet back on the section cut out once in place.
Offline Octoparrot
  • -Receive: 102
Re: Edition 30 rear brakes - Part 2
« Reply #1 on: May 26, 2020, 09:30:33 am »
I cut a piece out of mine and haven't had any problems, I didn't like hacking a new part up but there was no way I was taking the hub off to fit a couple of plates.
Offline terrier
  • -Receive: 39
  • My Ride: GTI now gone
« Reply #2 on: May 26, 2020, 09:35:15 am »
Cut off don't replace :happy2:
Offline titchy
« Reply #3 on: May 26, 2020, 10:15:59 am »
Mine undid with plenty of wd 40 overnight if buying new ones there are different sizes dependant on the disc size I was give ones that were to small
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=0v4p8nmstchc89o5rs4nfira0j&/topic,19740.0.html
« Reply #4 on: May 26, 2020, 05:36:54 pm »
Cutting them will leave bare metal and they will be more prone to rusting.
« Reply #5 on: May 29, 2020, 09:26:40 pm »
I bought a pair of new backing plates ages ago from VW, waiting until the rear wheel bearings wear out.....but they're stubbornly not wearing out  :grin:
Just do it properly.  Buy a pair of rear hub bolts from VW, take the bearings out, stick the new backing plates on, stick the new bolts in.  Done.  Cutting stuff is a proper hatchet harry job.
