Author Topic: Mk5 gti bwa engine swap help please :)  (Read 1038 times)
Offline Lowpow94
« on: June 01, 2020, 08:20:49 pm »
I have a 2008 mk5 gti with bwa engine, basically it’s gone bang.
I’m going to pick up another bwa engine on Wednesday, The engine is complete everything straight swap over, but will it run ok? Will it need to be tuned in or anything or just good to go?
Offline Dannyboi#722
  • My Ride: GOLF GTI EDITION 30 TTE480 BHP 446 & 443FT*LB FORGED (Mapped by R-Tech)
Re: Mk5 gti bwa engine swap help please :)
« Reply #1 on: June 01, 2020, 09:38:33 pm »
Providing there’s no other issues which as caused your engine to blow up. It’ll be fine to fit.
Offline Lowpow94
« Reply #2 on: June 01, 2020, 09:54:48 pm »
Hi thanks I had cam follow failure scored up camshaft damaged HPFP low oil pressure, so just going for a straight swap to another bwa I’ve picked up cheap
Offline omeydz
  • -Receive: 50
« Reply #3 on: June 01, 2020, 09:55:03 pm »
Does cost of a used BWA engine of unknown running outweight the cost of rebuilding your blown engine knowing your engine and using stronger components?
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
Offline Lowpow94
« Reply #4 on: June 01, 2020, 09:56:32 pm »
Rebuild say 1k -2k I picked engine up and getting fitted with labour all in for 1100
Drove the car engine coming out of all good with history etc
Offline LC5F
  • -Receive: 80
« Reply #5 on: June 01, 2020, 10:05:13 pm »
When you say "bang" how dramatic was this?
If it destroyed pistons, thrown a rod, smashed valves or simply wore out bearings you need to be very careful using anything taken over from old to the new engine that could be contaminated with debris.
Keep all the sensors from your existing engine together as they are known to be working.
It should just swap out, but its a good time to do housekeeping - Vital to clean out oil pick up, nice to de-carbon inlets, optional but good moral building to paint the block.
Lastly, afraid its more expense, but worth doing with engine out: new timing belt, new water pump, possibly crank seals, assuming its a manual look into clutch wear and also check the dual mass flywheel condition.
