Author Topic: P3040 Code and Rough Idle  (Read 1563 times)
Offline HMYGTI
« on: June 07, 2020, 02:04:33 am »
Hopefully someone can help with this, A few days ago my MK5 GTI developed a rough idle however it still drives fine and on cold start it idles at its higher revs fine but when it settles and drops the idle is incredibly rough. I checked for any fault codes and got the P3040 code for the crank position sensor. I was just curious to if anybody else has ever had this issue as i would have thought if it was showing this code it would cause more of an issue than just a rough idle.
Offline FJB
Re: P3040 Code and Rough Idle
« Reply #1 on: June 07, 2020, 01:24:46 pm »
I was getting an intermittent bad idle and would get a crank position sensor code, the code would clear and idle normally, but would return. A put a new crank position sensor in, which cured the problem. I noticed that there was some crud on the tip of the old sensor once I had removed it, as I already had the new one I installed it, but it may be worth you removing and cleaning yours before buying a new one.
Free £50 credit when you switch to Octopus Energy using this link: https://share.octopus.energy/pearl-marsh-31
