Author Topic: Intermittent Rattle/Flutter [Normal?]  (Read 977 times)
Offline JTI
  • -Given: 19
« on: June 08, 2020, 09:39:11 pm »
Hi, does anyone elses GTI make a slight flutter/rattle noise when the engine is on? Pretty sure mine has always done this but just noticing it more recently as I'm driving more with the music off.
When I'm driving slowly I get a slight rattle noise from the engine, it rattles for about 3 seconds and then stops for about 5, and then repeats in a loop. The faster I go the quicker the rattle repeats and then stops if that makes sense (it follows the same pattern just faster)? I haven't pinpointed this yet to either the harndess of acceleration or the speed I'm going.
I was wondering if this is just a normal TFSI noise or something else? Thanks.
Offline titchy
Re: Intermittent Rattle/Flutter [Normal?]
« Reply #1 on: June 09, 2020, 08:59:59 am »
Air box on securely?
Offline JTI
  • -Given: 19
« Reply #2 on: June 13, 2020, 11:43:06 pm »
I don't think it's anything loose as the noise follows an exact pattern. I had a good listen the other day in the engine bay, think it's coming from the box I've highlighted in the image below (what is this?), it's certainly in that area of the engine:
