Author Topic: Up to date brake upgrade advice  (Read 3280 times)
Offline TunstallGTI
  • Newbie
« on: June 14, 2020, 04:36:19 pm »
Hi guys,
Just bought a Mk5 GTI and wanted to upgrade the brakes as this will also be a track day car, (modified to stage 2 possibly).  Tried to read lots of forum posts but they all seem quite old from 2014-2017.  S3/R32 system seems popular but heavy, 340mm Boxster combo is not now recommended for almost any reasonable use on the vagbremtechnic site, also cost is a limiting factor, so looked at SF-Tuning Brembo set up whichwould come in around £1000.  Anyone used this set up or are there better alternatives for the same cost.  All advice gratefully received
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Re: Up to date brake upgrade advice
« Reply #1 on: June 15, 2020, 08:39:35 am »
I've got the Boxster calipes with braided lines and ferodo ds2500 pads and stock size discs. Really good set up and the calipers were about £150 from ebay. You can fit larger diameter discs if you want. My car has never been on a track so can't comment on how it would perform on one.
Offline TunstallGTI
  • Newbie
« Reply #2 on: June 15, 2020, 10:32:09 am »
Thanks for the reply. Do the calipers bolt straight on with standard size discs or do you have adaptor plates.  Wonder how they would stand up at Cadwell?
