Author Topic: Sudden loss of boost and strange hissing sound.  (Read 1786 times)
Offline JR.303
« on: June 28, 2020, 02:56:25 pm »
I booted it in 2nd and there was like a bursting sound of air escaping and I lost all boost.
I managed to limp home at pre boost revs and it just sort of hisses when it boosts with no power at all and it stalls on idle.
It has a new dv and pcv and the cam belt has only just been done maybe five miles ago.
This makes me wonder if a boost pipe was not secured properly or a pipe has split.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=i5dl4ft6np8iqbla06s9rl85td&/topic,19740.0.html
Re: Sudden loss of boost and strange hissing sound.
« Reply #1 on: June 28, 2020, 05:07:37 pm »
Sounds like a boost pipe yeah!
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #2 on: June 28, 2020, 05:13:18 pm »
Yes...it may just be a leaking pipe to hose fitting. You'll need to inspect all that is attached to the intake system...all attached between the intake to manifold. It may have only popped off a boost hose because wasn't connected securely.
But may also be a failed DV or PCV. You can eliminate the possibility of a faulty PCV quickly. To test the PCV; disconnect the PCV corrugated tube at the intake manifold, wipe the end, and blow into it with some force. It should seal. If so, move on and inspect all of the boost hose connections. If they are solid, and you can find no split/cracked tubing which attaches to the intake manifold, then you will need to inspect the DV.
Offline JR.303
« Reply #3 on: June 29, 2020, 07:02:46 am »
Thanks guys I will keep you posted.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #4 on: June 29, 2020, 11:16:10 pm »
There's more possibilities such as a broken or disconnected waste-gate, or a failed N75...but those others are common to begin with.
Offline JR.303
« Reply #5 on: June 30, 2020, 06:58:31 am »
Pipe blown off turbo. All fixed.
Now in for pre cat delete and oil pickup pipe clean, then stage 1 on the horizon.
