Author Topic: Engine Oil Control VVT broken connector repair  (Read 1793 times)
Offline jeno96
« on: July 08, 2020, 08:43:20 pm »
Hello!
On my Golf5GTI BWA, the VVT solenoid connector is broken, there is no issue (no error code) currently.
I wonder, if I am able to glue somehow the plastic part to hold it correctly.
I searched and found J-B WELD PLASTIC BONDER, which says it can resist up to 287C.
What do you think, without replacing the part, will it hold without any issue?
I also found the OEM code if someone needs 06f109257c.
Re: Engine Oil Control VVT broken connector repair
« Reply #1 on: July 10, 2020, 05:47:25 pm »
Hard to see which part is broken?  The connector or the VVT solenoid itself?  If the latter, it's not an expensive part and I'd just buy a new one personally.
Offline jeno96
« Reply #2 on: July 10, 2020, 10:27:10 pm »
The solenoid's connector only. (It should be straight, but it is bended currently and only the cable holds it). I hate when I need to replace the whole part because some plastic is broken, but true it is relatively cheap.
After some research, I find out that J-B WELD PLASTIC BONDER doesn't have any temp rating, so I go with JB weld original.
Offline muff1991
  • -Receive: 69
« Reply #3 on: July 22, 2020, 03:12:48 pm »
This same issue happened to me. I actually had a code flag up. After investigating.. i found the same issue you have there only my pins from inside the sensor were barely touching the points inside the connector plug hence the code. i removed the sensor and gently straightened the 2 pins from the sensor, glued the plastic back together and the problem was fixed!!
Confession: i only used super glue and after a week or so of this being fixed, i managed to lean on it or knock it while doing something else and it snapped again.. lol my own fault! so spent £20 and got an ebay cheapy.. it was around £90 for a genuine one and i didn't have the money at the time. Touch wood though.. the ebay cheapy is still going strong nearly 2 years on!
