Author Topic: Engine light is on and revs are high  (Read 1598 times)
Offline jeru31
« on: July 13, 2020, 10:00:20 am »
Morning peeps, So I have a Golf GTI Pirelli MK5. Of late the engine light has come on and the car is revving up to 2000 revs when idle, sometimes it comes down, other times it doesn't. I was reading up about this and it was suggested it could it be the PCV valve that needs replacing ? or do I need to take it to a garage? it's driving ok at the moment, thanks in advance
Offline TheBALDpuma
Re: Engine light is on and revs are high
« Reply #1 on: July 13, 2020, 04:02:20 pm »
Could be an air leak, i.e. it's sucking in too much because there's a hole in a pipe.
Offline LC5F
  • -Receive: 80
« Reply #2 on: July 13, 2020, 05:05:17 pm »
Engine running, take oil cap off.
When you remove the cap there should be resistance from vacuum and the engine revs should falter.
if its easy and no change in engine - PCV blown - easy DIY if its this
Offline jeru31
« Reply #3 on: July 13, 2020, 07:04:29 pm »
thanks guys, I will get it checked out with your recommendations
