Author Topic: Aerial base rubber  (Read 1941 times)
Offline imprezzaworks
Aerial base rubber
« on: July 19, 2020, 11:02:26 am »
After a new and spotted ebay do one on its own. Says you can pop it on without dropping the headlining?. Anyone bought one?
Offline FJB
Re: Aerial base rubber
« Reply #1 on: July 19, 2020, 12:04:46 pm »
You don't have to remove the headlining to remove the aerial, just pull down the plastic trim piece at the top of the rear hatch, it is just held on by clips, and there is enough room to undo the nut and remove, there is a gap between the headlining and roof.
Free £50 credit when you switch to Octopus Energy using this link: https://share.octopus.energy/pearl-marsh-31
« Reply #2 on: July 19, 2020, 12:24:26 pm »
Smashing thanks. Anyone used just the rubber from ebay?
Will price up the base through tps tomo
Offline LC5F
  • -Receive: 80
« Reply #3 on: July 19, 2020, 01:06:07 pm »
Is this the type that stretches over the aerial base?
For genuine seal you need to take the whole base and cable tails off the car to then install the seal, the cable has connectors tucked into the steel panels, if you are not familiar with them they are hard to disconnect - quite the faff
If I had to do this again I would be looking at the stretch type.
« Reply #4 on: July 19, 2020, 01:50:10 pm »
Yeah the one over the base
« Reply #5 on: July 20, 2020, 12:01:06 pm »
There are 2 types of base seal depending on year, just to add to the fun.  If your car is strange 2006/07 change over year model, it won’t state which one you need on ETKA.
Agreed with LC5F. It is indeed a faff. I just removed the aerial nut and it had just enough room to lift it off the roof to slide the new seal over the base.
« Reply #6 on: July 20, 2020, 12:04:37 pm »
Mines a 57 plate.
Have ordered one on ebay so will let you know
« Reply #7 on: July 20, 2020, 12:08:21 pm »
Mine is an 07 but has a lot of 06 parts on it, which causes a lot of head scratching at the dealer sometimes. It’s probably an 06 car but wasn’t registered until 07.
« Reply #8 on: July 20, 2020, 12:16:24 pm »
Time will tell ha ha
Offline muff1991
  • -Receive: 69
« Reply #9 on: July 20, 2020, 05:12:17 pm »
i could do with replacing mine too, its a bit perished and rather unsightly.
« Reply #10 on: July 20, 2020, 06:02:03 pm »
Will let you know mate.
« Reply #11 on: July 22, 2020, 10:06:15 am »
Yeah seems to work well. Bit of heat to help it squeeze on.
Not a 100% fit but more than happy
Offline muff1991
  • -Receive: 69
« Reply #12 on: July 22, 2020, 12:33:12 pm »
Thanks for the update mate, i meet go this route too.
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #13 on: July 22, 2020, 01:10:02 pm »
I've left the part in a cup of hot water for a few mins so it's super flexible.
« Reply #14 on: July 22, 2020, 01:38:12 pm »
I did similar mate
