Author Topic: Golf gti fault codes  (Read 1366 times)
Offline Kee1994
« on: July 19, 2020, 01:48:17 pm »
My revs are hanging around 1500rpm for about 5 seconds. When coming to a stop and when just revving
Fault codes are leak in air intake system p2279 and idle control system higher than expected p0507
Also I have a ramair airfilter fitted
Any ideas guys ? Thanks.
Sent from my SM-G975F using Tapatalk
Offline Enviousog
Re: Golf gti fault codes
« Reply #1 on: July 19, 2020, 02:44:58 pm »
I had this issue when I put my oversized ram air induction on, make sure your clamps are real tight on the connections, i impact wrenched mine to make sure and I never seen it again... although mkvs do rev hang a bit anyway from factory, something to do with emissions i believe.
Someone will correct me if I'm wrong
Offline Kee1994
« Reply #2 on: July 19, 2020, 02:50:11 pm »
Did you have codes to ?
Offline Enviousog
« Reply #3 on: July 19, 2020, 02:53:46 pm »
Yes, I think one of your jubilee clips isn't tight enough or it could be a faulty PCV
« Reply #4 on: July 20, 2020, 12:05:14 pm »
Correct  :happy2:  Most DBW engines do that. It delays throttle closure slightly to burn off any residual fuel in the cylinders. It seems to be misunderstood as ‘throttle lag’ on a lot of forums but DBW can go from 0 - 100% way quicker than a mechanical throttle  :smiley:
