Author Topic: Multifunction Steering wheel Help!  (Read 10730 times)
hufcforpromotion
« on: January 04, 2009, 09:08:50 pm »
Hi all!
         I have just got a bargin off e-bay for my wife's Touran Sport DSG. Link:- http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=280299304929
My wife's Touran allready has the multifunction wheel and hi-line comp and every other option going on her car but what I really want to know will the DSG paddles on the new wheel work or will I need to get another module to allow them to work?
Cheers John
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Multifunction Steering wheel Help!
« Reply #1 on: January 04, 2009, 10:45:49 pm »
You might be ok John, if the car is a high spec with a MFSW already it's more likely just a swap and a tweak with the VCDS.
Stu...
« Reply #2 on: January 05, 2009, 02:11:44 pm »
how the hell did that happen? i put an 80quid bid on that last night?!
« Reply #3 on: January 05, 2009, 02:25:28 pm »
just spoke to mike at VW speed and they dont stock any new ones now
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #4 on: January 05, 2009, 02:28:13 pm »
I'd say that guy cancelled the auction.
Stu...
« Reply #5 on: January 05, 2009, 04:55:08 pm »
hmm..probably, ive just ordered a brand new one instead. is there any other bits i need to make the buttons work?
i have a highline CECM, just wondered if id need another box of tricks from VW/a place to plug the buttons in?
hufcforpromotion
« Reply #6 on: January 05, 2009, 05:38:07 pm »
I arranged an outside of e-bay agreement with the seller! sorry!
Just out of interest how much did the brand new one cost you?
« Reply #7 on: January 05, 2009, 05:39:09 pm »
haha...250quid!!
hufcforpromotion
« Reply #8 on: January 05, 2009, 05:44:07 pm »
Well makes mine a bargin at £110 delivered! Was too cheap to pass up! Does your car have multifunction wheel standard and have you gone for one with the dsg paddles?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: January 05, 2009, 06:39:26 pm »
The MFSW will normally have a seperate controller inside (behind the airbag)  assuming you also got the airbag then you won't need a new airbag wiring loom, if you didn't then you will!!
It's always a lottery with these wheels as it does depend on the other parts you have such as slip ring and steering controller.  I would suggest you attempt the fit and if it doesn't work then you'll need to buy the slip ring and controller.  Be prepared to add approx £200 to the price of the wheel (VAG RRP's) if you do need them.
If either of you are South then let me know as I have the tools etc to help you out.
Stu...
hufcforpromotion
« Reply #10 on: January 05, 2009, 06:43:24 pm »
Our Touran allready has the MFSW fitted so the original airbag should just slot in place! The only thing i am not sure about is if the paddles will work with the DSG!?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #11 on: January 05, 2009, 06:46:10 pm »
As I said above I think they will.  Coding is simple if you have VCDS.
Stu...
hufcforpromotion
« Reply #12 on: January 05, 2009, 06:49:11 pm »
Is the coding required to get the dsg paddles to work!? I will get Star Performance to code the wheel if needs be as I don't know anyone else up in the scotland who could do it!
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #13 on: January 05, 2009, 06:56:40 pm »
It will depend on the current coding of your controller -
http://wiki.ross-tech.com/index.php/VW_Golf_%281K%29_Steering_Wheel#Coding
If Auto Transmission is enabled then you should be ok.
Stu...
hufcforpromotion
« Reply #14 on: January 05, 2009, 07:06:23 pm »
Thanks for the Info Stu! Hopefully if it does not work then should just be able to enable via vagcom!? I won't get to fit this until march as I am overseas serving in Afghanistan!
