Author Topic: Info required from anyone with an intercooler, HPFP, and boost gauge fitted  (Read 4060 times)
Offline xxx_mojo_xxx
  • MUBster DUBster
What's the vacuum pressure being shown during idle?
Thanks,
Mo
iirc should be around -20 but don't quote me on it...
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
yep around 20mmHg vacuum at idle  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
  • MUBster DUBster
Is it a good or bad thing if it's below 20?  Should I be expecting imminent failure?
What intercoolers do you have?
If it deviates much from -20 then I would look for a vacuum leak.
Offline GTIjames
I'm running the defi boost gauge with apr hpfp and forge fmic
When I first turn on the engine I have noticed boost sits a little higher than 22hg around 15hg the revs also sit a liitle higher c1100rpm rather than usual 8krpm
It soon settles down once warmed up and boost will then sit at 22hg
I have suspected a vacuum leak but holds boost well, so just put up with it  :happy2:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
agree not seen a gti yet thats below 20mmHg when warm ...
first place to check are the boost guage connections, which guage and how have you fitted it (t piece etc?)
if the revs are above idle then itll naturally be less of a vaccuum, mines the same during the warm up phase its normal
Red ED35 5dr DSG
BLOG | BUILD
  • MUBster DUBster
Where would I start checking for a vacuum leak?
Am I correct to think the turbo boost pipe and intercooler pipes only carry positive boost?
I think most find that the issue lies where you tap off the vacuum for the boost gauge so I would check that first.
  • MUBster DUBster
Sorry to be really ignorant...but does anyone have a pic?
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
the way in which a boost/vacuum signal has been taken depends on the make/type and parts you have fitted to your car.
normally there will be a T piece fitted under the engine cover RHS as looking from front and a small bore pipe running into the cabin then into boost gauge.
(or if its a DEFI electrical gauge then the small bore pipe runs to a sensor usually in the engine bay then an electrical cable to the cabin/gauge)
if you have a forge DV fitted then theres also a 'takeoff' point there which can be used negating the need for a t piece.
Id look for
1. broken plastic  t piece with a hariline crack , put a metal one in there ...
2. check all fittings that have been touched during install, inc the one on the back of the boost guage
another thing you can try is spraying some fairy liquid water around connections and listening/checking gauge.
you may get a momentary inc in vacuum  or change in sounds if it temporarily stops the leak.
or with some throttle get bubbles .....
Red ED35 5dr DSG
BLOG | BUILD
Offline NEWEY
    • Flickr
once warm mine sits at 22hg
TSR big turbo mk5 golf gti
Offline ukdub
Same as mine when warm.  Read using a Defi boost gauge.  :happy2:
Laser Blue with K04 power, APR hardware controlled by REVO 2+ software
Chassis by KW V3's, Whiteline and a hint of PRO race 1.2's
Brakes by Brembo 4 pots
Offline NEWEY
    • Flickr
sorry forgot to add mine is a newsouth boost gauge :)
  • MUBster DUBster
Thanks for the tips guys especially around isolating a potential vacuum leak.
I was using a Forge DV and running the 'vacuum' pipe directly from it.  I figure if everyone has a reading of 22 then there might not be a problem after all!!!
I guess the intercooler and HPFP must have increased the vacuum pressure.  As a test I removed my Forge DV and went back to the OEM one (rev. D)  and the read outs are the same.
I must say I'm missing the "whoosh" noise from the Forge DV.... not sure if I should fit that one back again.  Open to opinions?
