Author Topic: brake upgrade MK5 GTI  (Read 3080 times)
Offline lloydy88
« on: July 24, 2020, 05:49:17 pm »
now then everyone...
looking at upgrading brakes on the old MK5 and I've become tempted by the mk7 R caliper upgrade and I have a couple of questions!
firstly, do they bolt to the MK5 GTI carrier brackets or do they have their own different/bigger carriers? I've seen a lot on eBay which are reasonably priced but none of them have carriers with them!
secondly, with the MK7 R caliper installed do they allow for larger discs and if so what size?
cheers!
Offline colesey
  • -Receive: 89
Re: brake upgrade MK5 GTI
« Reply #1 on: July 24, 2020, 06:46:49 pm »
They bolt straight on and use 340/30mm discs.
Offline Octoparrot
  • -Receive: 104
« Reply #2 on: July 24, 2020, 06:48:26 pm »
https://www.mk5golfgti.co.uk/forum/index.php/topic,108106.0.html Read this it should answer all your questions.
Offline lloydy88
« Reply #3 on: July 24, 2020, 07:25:26 pm »
thanks guys!!! :happy2:
  • -Receive: 692
« Reply #4 on: July 24, 2020, 07:57:34 pm »
Bolt on. MK5 hoses fit straight on as well  :happy2:  Although you might want to refresh those with new ones as rubber doesn't age well.  They're not expensive from VW.
Offline LC5F
  • -Receive: 80
« Reply #5 on: July 24, 2020, 08:22:54 pm »
Delighted with mine, performance is exactly as others have described here on the forum.
I was really lucky to find some on ebay, the pro breaker had not done their homework and listed them silly cheap.
  • -Receive: 692
« Reply #6 on: July 24, 2020, 08:31:27 pm »
I have to concur Mr LC 5F in the house......
I'm not normally an advocate of heavy old OEM brakes, but I've been very impressed with the MK7 calipers with Clubsport S discs.  Such a good combo.  With the Passat B6 control arms and knuckles, the weight gain from the hefty iron calipers and big old discs are negated  :happy2:
Offline lloydy88
« Reply #7 on: July 25, 2020, 07:49:16 pm »
Thanks everyone! Guess I best get searching!!
