Author Topic: Updated Canbus Gateway RCD330?  (Read 1233 times)
Offline OldGTI
« on: August 01, 2020, 02:51:36 pm »
I have been told I need un updated Canbus Gateway to not get battery drain when installing a RCD330 in a 2007 gti. I have ordered a 7N0 907 530 gateway. Is this plug and play or will I need to get the gateway coded. Thanks
Offline shoaybmakda
  • -Receive: 54
Re: Updated Canbus Gateway RCD330?
« Reply #1 on: August 01, 2020, 03:48:20 pm »
Yes it will need coding in
Offline OldGTI
« Reply #2 on: August 01, 2020, 06:18:52 pm »
Is that cbus the best way or is it better to just use one of the power from the cigarette lighter type fixes that are all over the internet?
Offline gege12372
« Reply #3 on: August 02, 2020, 07:05:42 pm »
I’ve nicked power from the fuse box as per this guide for mine: https://www.mk5golfgti.co.uk/forum/index.php?topic=37977.0
Can confirm no drain but will be getting my new gateway coded next week as a more elegant solution.
Offline OldGTI
« Reply #4 on: August 02, 2020, 10:09:04 pm »
I have been told it is just vcds coding so hopefully not a big deal
