Author Topic: My good luck continues  (Read 2662 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« on: March 13, 2010, 02:12:23 pm »
Well, yesterday it was the front fender, today the GTI decided to try and be a Daihatsu charade, 3 cylinders and didn't pull at all  :confused:
Luckily i was only 4 kilometers from home, so back i went, on with the vcds, and my suspision were confirmed, Coilpack on cylinder 1 had gone bad  :fighting:
Luckily i  have my old treasure chest so off to the shed i went and found 4 spare coilpacks, all in all it took under 30 min. from it acted up 'till the car was back in shape
My point to this story is; a thank you to you all, as all the knowledge i have of VW is gathered in these forums meaning from all you guys  :congrats:  :notworthy:
« Last Edit: March 13, 2010, 02:35:32 pm by danishmkvgti »
Over the top mod list ;o)
Re: My good luck continues
« Reply #1 on: March 13, 2010, 02:41:38 pm »
Ok Well get lost now, because all your bad luck will be rubbing off on us lot soon.  :signLOL:
  • -Given: 243
  • -Receive: 154
« Reply #2 on: March 13, 2010, 03:16:35 pm »
nice to know i'm being loved.................................................. somewhere else  :laugh:   :booty:
Offline 182_blue
  • -Receive: 54
« Reply #3 on: March 13, 2010, 07:43:53 pm »
Good you got it sorted, out of interest what does the VCDS report for a faulty coilpack ?
  • -Given: 243
  • -Receive: 154
« Reply #4 on: March 13, 2010, 08:08:27 pm »
000768 - Random/Multiple Cylinder Misfire Detected
               P0300 - 001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 182977 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:04:33
             Freeze Frame:
                    RPM: 3305 /min
                    Load: 35.7 %
                    Speed: 112.0 km/h
                    Temperature: 84.0°C
                    Temperature: 2.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.478 V
000769 - Cylinder 1: Misfire Detected
               P0301 - 001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 182977 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:04:33
             Freeze Frame:
                    RPM: 3305 /min
                    Load: 35.7 %
                    Speed: 112.0 km/h
                    Temperature: 84.0°C
                    Temperature: 2.0°C
                    Voltage: 14.478 V
Offline 182_blue
  • -Receive: 54
« Reply #5 on: March 13, 2010, 08:45:06 pm »
Thx, do you have the vw part number for a coil pack ?
  • -Given: 243
  • -Receive: 154
« Reply #6 on: March 13, 2010, 08:52:19 pm »
there might be a newer revision, but my spare ones has rev.number 07K 905 715 C[/color :happy2:]
